Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit 4c63a601b90db131e92d3f6f6da6a4bc2b287df1)
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing
RESET_MOCI#.
Please note that module hardware versions up to V1.1A will already
release RESET_MOCI# in hardware coming out of reset.
Please further note that with this change the USB hub on the Apalis
Evaluation board is kept in reset in U-Boot and therefore none of its
ports are operational in U-Boot.
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit 5b5de78b4a6ff8c2bbd71a6b51d6fdf32f420eef)
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
