path: root/board/topic
2020-04-27xilinx: Introduce board_late_init_xilinx()Michal Simek
This function should keep common shared late configurations for Xilinx SoCs. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-14arm: zynq: Remove low level UART settingMichal Simek
There is no reason to do serial initializationin low level code. Uart driver does it already based on DT. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24board: topic-miamiplus: Run IO PLL at 1000 MHzMike Looijmans
The miamiplus can use GEM0 through MIO pins, which requires a 125 MHz TX clock to be generated. With the IO PLL at 1200 MHz this isn't possible, so change it to run at 1000 and adjust the divisors accordingly. Also set the GEM0 clock source to MIO instead of EMIO. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-24topic-miamiplus: Run CPU at 800MHz for speedgrade-2Mike Looijmans
The miamiplus contains a speedgrade-2 device, which may run the CPU at 800MHz. Change the PLL setting to 800MHz, and adapt the setpoints in the devicetree. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-29arm: zynq: Move common ps7_init* initialization to arch codeMichal Simek
This patch is based on work done in topic board where the first address word also storing operation which should be done. This is reducing size of configuration data. This patch is not breaking an option to copy default ps7_init_gpl* files from hdf file but it is doing preparation for ps7_init* consolidation. The patch is also marking ps7_config as weak function. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-20arm: zynq: Add support for the topic-miamilite system-on-moduleMike Looijmans
The topic-miamilite SoM contains a Zynq xc7z010 SoC, 1GB DDR3L RAM, 64MB dual-parallel QSPI NOR flash and clock sources. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM: zynq: Add support for the topic-miami system-on-modules and carrier boardsMike Looijmans
The topic-miami SoMs contain a Zynq xc7z015 or xc7z030 SoC, 1GB DDR3L RAM, 32MB QSPI NOR flash and 256MB NAND flash. The topic-miamiplus SoMs contain a Zynq xc7z035, xc7z045 or xc7z100 SoC, 2x 1GB DDR3L RAM, 64MB dual-parallel QSPI flash, clock sources and a fan controller. The "Florida" carrier boards add SD, USB, ethernet and other interfaces. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
