path: root/board/timll
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-15mmc: replace CONFIG_GENERIC_MMC with CONFIG_MMCMasahiro Yamada
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig. We do not need two options for the same feature. Deprecate the former. This commit was generated with the sed script 's/GENERIC_MMC/MMC/' and manual fixup of drivers/mmc/Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-03-19ti: boot: Register the MMC controllers in SPL in the same way as in u-bootJean-Jacques Hiblot
To keep a consistent MMC device mapping in SPL and in u-boot, let's register the MMC controllers the same way in u-boot and in the SPL. In terms of boot time, it doesn't hurt to register more controllers than needed because the MMC device is initialized only prior being accessed for the first time. Having the same device mapping in SPL and u-boot allows us to use the environment in SPL whatever the MMC boot device. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-01-20serial, ns16550: bugfix: ns16550 fifo not enabledHeiko Schocher
commit: 65f83802b7a5b "serial: 16550: Add getfcr accessor" breaks u-boot commandline working with long commands sending to the board. Since the above patch, you have to setup the fcr register. For board/archs which enable OF_PLATDATA, the new field fcr in struct ns16550_platdata is not filled with a default value ... This leads in not setting up the uarts fifo, which ends in problems, when you send long commands to u-boots commandline. Detected this issue with automated tbot tests on am335x based shc board. The error does not popup, if you type commands. You need to copy&paste a long command to u-boots commandshell (or send a long command with tbot) Possible boards/plattforms with problems: ./arch/arm/cpu/arm926ejs/lpc32xx/devices.c ./arch/arm/mach-tegra/board.c ./board/overo/overo.c ./board/quipos/cairo/cairo.c ./board/logicpd/omap3som/omap3logic.c ./board/logicpd/zoom1/zoom1.c ./board/timll/devkit8000/devkit8000.c ./board/lg/sniper/sniper.c ./board/ti/beagle/beagle.c ./drivers/serial/serial_rockchip.c Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-03-14ARM: Various: Future-proof serial platdataAdam Ford
A few boards still use ns16550_platdata structures, but assume the structure is going to be in a specific order. By explicitly naming each entry, this should also help 'future-proof' in the event the structure changes. Tested on the Logic PD Torpedo + Wireless. I only changed a handful of devices that used the same syntax as the Logic board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods and Alexander Graf. Signed-off-by: Adam Ford <aford173@gmail.com> V6: Add fix to arch/arm/cpu/armv7/am33xx/board.c V5: Add fix to arch/arm/cpu/arm926ejs/lpc32xx/devices.c V4: Fix subject heading V3: Remove reg_offset out in all the structs. It was reverted out, and and if it did exist, it would get initialized to 0 by default. V2: I hastily copy-pasted the boards without looking at the UART number. This addresses 3 boards that use UART3 and not UART1. Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-11lpc32xx: remove surplus clock cycle in PL175 WAIT_OEN configVladimir Zapolskiy
According to ARM PrimeCell PL175 documentation WAIT_OEN config value is defined without any additional clocks added to the value set by a client, the change fixes the wrong interface to WAIT_OEN config. The change also touches a single user of LPC32xx EMC and corrects configured "output enable delay" value on its side according to the changed interface. No functional change intended. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-12lpc32xx: devkit3250: add spl build supportVladimir Zapolskiy
The change adds SPL build support to Timll DevKit3250 board, the generated SPL image can be uploaded over UART5, JTAG or stored on NAND. SPL is designed to load U-boot image from NAND. All new NAND chip defines in board configuration are needed by SPL NAND "simple" framework, the framework is used to reduce potentially duplicated code from LPC32xx SLC NAND driver. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-12lpc32xx: devkit3250: update of board configurationVladimir Zapolskiy
This change adds more peripherals to Timll DevKit3250 board, namely MAC and SMSC phy, SLC NAND, GPIO, SPI and I2C. Also the default serial console is changed to UART5, added an option to pass device tree blob by means of bootm, predefined environment variables are slightly extended and reserved space on NAND to store user defined U-boot environment. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-01-13arm: omap3: devkit8000: inherit from ti_omap3_common.hAnthoine Bourgeois
Signed-off-by: Anthoine Bourgeois <anthoine.bourgeois@gmail.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-01OMAP3: drop CONFIG_SPL_OS_BOOT_KEY and use local defineStefano Babic
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2012-12-10Pass sdrc timing values through board_sdrc_timings structurePeter Barada
Instead of passing individual registers by value to board_get_mem_timings, pass a board_mem_timings structure pointer for the board files to fill in. Pass same structure pointer to write_sdrc_timings. This saves about 90 bytes of space in SPL. Signed-off-by: Peter Barada <peter.barada@logicpd.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-05-15devkit3250: add Timll DevKit3250 board initial supportVladimir Zapolskiy
This change adds a basic support for Embest/Timll DevKit3250 board, NOR and UART are the only supported peripherals for a moment. The board doesn't require low-level init, because the initial SDRAM and GPIO configuration is performed during kickstart bootloader execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-03-27devkit8000: Implement and activate direct OS bootSimon Schwarz
- Implements spl_start_uboot() for devkit8000 - Add configs to activate direct OS boot from SPL Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> CC: Tom Rini <tom.rini@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2012-03-27devkit8000/spl: init GPMC for dm9000 in SPLSimon Schwarz
Linux crashes if the GPMC isn't configured for the dm9000. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> CC: Tom Rini <tom.rini@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-12-24Devkit8000: Switch over to enable_gpmc_cs_configThomas Weber
Use enable_gpmc_cs_config instead of local writing timing configuration for GPMC. Signed-off-by: Thomas Weber <weber@corscience.de>
2011-12-06OMAP3 SPL: Rework memory initalization and devkit8000 supportTom Rini
This changes to making the board be responsible for providing the memory initialization timings in SPL and converts the devkit8000 to this framework. In SPL we try and initialize both CS0 and CS1. Cc: Frederik Kriewitz <frederik@kriewitz.eu> Signed-off-by: Tom Rini <trini@ti.com>
2011-10-27devkit8000: protect board_mmc_initSimon Schwarz
This function is also defined in omap-common/spl_mmc.de so the implementation in devkit8000.c was protected by a ifdef. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
2011-09-30devkit8000: Add nand-spl support for new SPLSimon Schwarz
Add NAND SPL support to the devkit8000 config Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04devkit8000: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-20Devkit8000: Adapt changes to ARM relocation supportThomas Weber
Fix compilation of Devkit8000 after introduction of ARM relocation support. Signed-off-by: Thomas Weber <weber@corscience.de> Adapt to TEXT_BASE => CONFIG_SYS_TEXT_BASE rename. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-01-04TWL4030: make LEDs selectable for twl4030_led_init()Grazvydas Ignotas
Not all boards have both LEDs hooked, so enabling both on boards with single LED will just waste power. Make it possible to choose LEDs by adding argument to twl4030_led_init(). Using this turn on only LEDB for pandora, leave both LEDs on for all other boards, as it was before this patch. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-10-13OMAP3: Clean up whitespace in mux configsOlof Johansson
Switch from space-based indentation to tab-based in mux configs, as pointed out by WD at: http://lists.denx.de/pipermail/u-boot/2009-September/061241.html Nothing but whitespace changes in this patch (diff -w gives no output). Signed-off-by: Olof Johansson <olof@lixom.net>
2009-09-05Add support for the DevKit8000 boardFrederik Kriewitz
This patch adds support for the DevKit8000 board. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
