According to ARM PrimeCell PL175 documentation WAIT_OEN config value
is defined without any additional clocks added to the value set by a
client, the change fixes the wrong interface to WAIT_OEN config.
The change also touches a single user of LPC32xx EMC and corrects
configured "output enable delay" value on its side according to the
changed interface.
No functional change intended.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
The change adds SPL build support to Timll DevKit3250 board, the
generated SPL image can be uploaded over UART5, JTAG or stored on
NAND. SPL is designed to load U-boot image from NAND.
All new NAND chip defines in board configuration are needed by
SPL NAND "simple" framework, the framework is used to reduce
potentially duplicated code from LPC32xx SLC NAND driver.
This change adds more peripherals to Timll DevKit3250 board, namely
MAC and SMSC phy, SLC NAND, GPIO, SPI and I2C.
Also the default serial console is changed to UART5, added an option
to pass device tree blob by means of bootm, predefined environment
variables are slightly extended and reserved space on NAND to store
user defined U-boot environment.
Signed-off-by: Anthoine Bourgeois <anthoine.bourgeois@gmail.com>
Boards using the TWL4030 regulator may not all use the LDOs the same way
(e.g. MMC2 power can be controlled by another LDO than VMMC2).
This delegates TWL4030 MMC power initializations to board-specific functions,
that may still call twl4030_power_mmc_init for the default behavior.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Reviewed-by: Tom Rini <trini@ti.com>
[trini: Fix omap3_evm warning, add twl4030.h]
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
Becuase the board select menu in arch/arm/Kconfig is too big,
move the OMAP3 board select menu to omap3/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap3
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
In master we had already taken a patch to fix the davinci GPIO code for
CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support
DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these
conflicts manually and comment the #else/#endif lines for clarity.
arch/arm/include/asm/arch-davinci/gpio.h
drivers/gpio/da8xx_gpio.c
Add check for write protection in omap mmc driver.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Implement driver check for card detection.
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is
not required to have a general CONFIG_ option. Rename it and
define it in board directory.
Instead of passing individual registers by value to board_get_mem_timings,
pass a board_mem_timings structure pointer for the board files to fill in.
Pass same structure pointer to write_sdrc_timings. This saves about
90 bytes of space in SPL.
Signed-off-by: Peter Barada <peter.barada@logicpd.com>
Also drop a few files referring to no longer / not yet supported
boards.
Cc: Stefan Roese <sr@denx.de>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Jason Jin <jason.jin@freescale.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Add parameters to the OMAP MMC initialization function so the board can
mask host capabilities and set the maximum clock frequency. While the
OMAP supports a certain set of MMC host capabilities, individual boards
may be more restricted and the OMAP may need to be configured to match
the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example.
Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
This change adds a basic support for Embest/Timll DevKit3250 board,
NOR and UART are the only supported peripherals for a moment. The board
doesn't require low-level init, because the initial SDRAM and GPIO
configuration is performed during kickstart bootloader execution.
Acked-by: Marek Vasut <marek.vasut@gmail.com>
- Implements spl_start_uboot() for devkit8000
- Add configs to activate direct OS boot from SPL
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
CC: Tom Rini <tom.rini@gmail.com>
CC: Stefano Babic <sbabic@denx.de>
CC: Wolfgang Denk <wd@denx.de>
Linux crashes if the GPMC isn't configured for the dm9000.
Use enable_gpmc_cs_config instead of local writing
timing configuration for GPMC.
Signed-off-by: Thomas Weber <weber@corscience.de>
This changes to making the board be responsible for providing the
memory initialization timings in SPL and converts the devkit8000
to this framework. In SPL we try and initialize both CS0 and CS1.
Cc: Frederik Kriewitz <frederik@kriewitz.eu>
This function is also defined in omap-common/spl_mmc.de so the implementation
in devkit8000.c was protected by a ifdef.
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Add NAND SPL support to the devkit8000 config
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc
driver. This patch is based on the work done for Beagle, etc.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Fix compilation of Devkit8000 after introduction of
ARM relocation support.
Adapt to TEXT_BASE => CONFIG_SYS_TEXT_BASE rename.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Not all boards have both LEDs hooked, so enabling both on
boards with single LED will just waste power. Make it
possible to choose LEDs by adding argument to
twl4030_led_init().
Using this turn on only LEDB for pandora, leave both LEDs
on for all other boards, as it was before this patch.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Switch from space-based indentation to tab-based in mux configs, as pointed
out by WD at:
http://lists.denx.de/pipermail/u-boot/2009-September/061241.html
Nothing but whitespace changes in this patch (diff -w gives no output).
This patch adds support for the DevKit8000 board.
Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
