path: root/board/timll/devkit3250
2012-05-15devkit3250: add Timll DevKit3250 board initial supportVladimir Zapolskiy
This change adds a basic support for Embest/Timll DevKit3250 board, NOR and UART are the only supported peripherals for a moment. The board doesn't require low-level init, because the initial SDRAM and GPIO configuration is performed during kickstart bootloader execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
