path: root/board/ti
2015-04-16ti: dwc3: Enable clocks in enable_basic_clocks() in hw_data.cKishon Vijay Abraham I
Commit d3cfcb3 (ARM: DRA7: Enable clocks for USB OTGSS and USB PHY) changed the member names of prcm_regs from cm_l3init_usb_otg_ss_clkctrl to cm_l3init_usb_otg_ss1_clkctrl and from cm_coreaon_usb_phy_core_clkctrl to cm_coreaon_usb_phy1_core_clkctrl in order to differentiate between the two dwc3 controllers present in dra7xx/am43xx and enabled these clocks in enable_basic_clocks() in hw_data.c. However these clocks continued to be enabled in board files/driver files for dwc3 host mode functionality causing compilation break with few configs. Fixed it here by making all the clocks enabled in enable_basic_clocks() and removing it from board files/driver files here. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-04-14usb: modify usb_gadget_handle_interrupts to take controller indexKishon Vijay Abraham I
Since we support multiple dwc3 controllers to be existent at the same time, in order to handle the interrupts of a particular dwc3 controller usb_gadget_handle_interrutps should take controller index as an argument. Hence the API of usb_gadget_handle_interrupts is modified to take controller index as an argument and made the corresponding changes to all the usb_gadget_handle_interrupts calls. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14board: ti: AM43xx: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in am43xx board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14board: ti: DRA7: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in dra7xx board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-28malloc_f: remove redundant defalut values of CONFIG_SYS_MALLOC_F_LENMasahiro Yamada
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig as 0x400. Each defconfig or Kconfig need not repeat the same value. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-02MAINTAINERS, git-mailrc: Update my email addressTom Rini
2015-02-24ARM: remove tnetv107x board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chan-Taek Park <c-park@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-16keystone2: ddr3: eliminate using global ddr3_size variableVitaly Andrianov
KS2 ddr3 initialization uses ddr3_size global variable before u-boot relocation. Even if the variable is not being used after relocation, writing to it corrupts relocation table. This patch removes the global ddr3_size variable and uses local one instead. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Tested-by: Nishanth Menon <nm@ti.com>
2015-02-16ARM: DRA7: EMIF: Update SDRAM_REF_CTRL register valueLokesh Vutla
The value in SDRAM_REF_CTRL controls the delay time between the initial rising edge of DDR_RESETn to rising edge of DDR_CKE (JEDEC specs this as 500us). In order to achieve this, SDRAM_REF_CTRL should be written with a value corresponding to 500us delay before starting DDR initialization sequence, and configure proper value at the end of sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13board: ti: am43xx: add support for AM43xx Industrial Development KitFelipe Balbi
AM43xx Industrial Development Kit is a new board based on AM437x line of SoCs. Targetted at Industrial Automation applications, it comes with EtherCAT, motor control and other goodies. Thanks to James Doublesin for all the help. Cc: James Doublesin <doublesin@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-13board: ti: am43xx: take care of all OPPsFelipe Balbi
Make sure that all OPPs are checked on scale_vcores(). While at that also fix 600MHz VDD_MPU voltage according to AM437x Data Manual available at [1]. Table 5-3 on that document, lists all valid voltages per frequency. [1] http://www.ti.com/lit/ds/symlink/am4379.pdf Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-13board: ti: am43xx: replace if else if else with a switchFelipe Balbi
A switch statement fits better in this case, specially considering we have a few extra frequencies to use. Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-13arm: am437x: Correct PLL frequency for 25MHzJames Doublesin
The frequencies for 25MHz in dpll_per were out of spec for 25MHz, correct. Signed-off-by: James Doublesin <doublesin@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-13arm: am437x: Enable hardware leveling for EMIFJames Doublesin
Switch to using hardware leveling for certain parameters on the EMIF rather than using precalculated values. Doing this also means we have a common place now between am437x and am335x for setting emif_sdram_ref_ctrl with a value for the correct delay length. Tested-by: Felipe Balbi <balbi@ti.com> Tested-by: Tom Rini <trini@ti.com> Signed-off-by: James Doublesin <doublesin@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-13arm: am437x: PLL values for all input frequenciesJames Doublesin
Need to provide PLL values for all possible input frequencies (19.2, 24, 25, 26MHz). Values provide are also optimized for jitter (needed especially for PER PLL and DDR PLL). Signed-off-by: James Doublesin <doublesin@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-01-12omap: beagle_x15: add MAINTAINERSMasahiro Yamada
Commit 1e4ad74b875f (beagle_x15: add board support for Beagle x15) missed to add board/ti/beagle_x15/MAINTAINERS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Felipe Balbi <balbi@ti.com>
2015-01-08doc: fix spelling errors in am335x/READMEJeremiah Mahler
Fix several spelling errors and replace the invalid word "architectured" with "designed". Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com>
2015-01-05ARM: OMAP4: Panda: rework DMM logicNishanth Menon
Part of DMM logic is reuse from commit 47a4bea6af77b01d59a410d09a4c34b2dd14cf50 ("ARM: omap4: Update sdram setting for panda rev A6") Which broke SDP4430 with ES2.3 (uses old DDR). So, to maintain support for newer DDR used in Panda ES rev B3, we should, in addition to the commit 675cc77a3ae45e8b0ec17128563264d4a509f628 ("ARM:OMAP4+: panda-es: Support Rev B3 Elpida DDR2 RAM"), DDR timings, also do DMM configuration specific to Panda. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-12-04ARM: OMAP5: DRA7xx: Fix misleading comments in mux_data.hLubomir Popov
The comments on the QSPI pad assignments erronously swapped the qspi1_d0 and qspi1_d1 functionality and could cause confusion. QSPI1_D[0] is in fact muxed on pad U1 (gpmc_a16), and QSPI1_D[1] - on pad P3 (gpmc_a17). Fixing comments. Signed-off-by: Lubomir Popov <l-popov@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-04beagle_x15: add board support for Beagle x15Felipe Balbi
BeagleBoard-X15 is the next generation Open Source Hardware BeagleBoard based on TI's AM5728 SoC featuring dual core 1.5GHZ A15 processor. The platform features 2GB DDR3L (w/dual 32bit busses), eSATA, 3 USB3.0 ports, integrated HDMI (1920x108@60), separate LCD port, video In port, 4GB eMMC, uSD, Analog audio in/out, dual 1G Ethernet. For more information, refer to: http://www.elinux.org/Beagleboard:BeagleBoard-X15 Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap5: don't enable misc_init_r by defaultFelipe Balbi
Out of all OMAP5-like boards, only one of them needs CONFIG_MISC_INIT_R, so it's best to enable that for that particular board only, instead of enabling for all boards unconditionally. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-13kconfig: arm: select CPU_V7 for some new boardsMasahiro Yamada
This commit adds "select CPU_V7" for some new boards that were not covered by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). Redundant "SYS_CPU" defines and "string" directives should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-11-06ks2_evm: board: remove sprintf for simple stringKhoronzhuk, Ivan
There is no reason to sprintf simple string. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05ks2_evm: readme: add k2l evm board informationKhoronzhuk, Ivan
Currently Keystone2 Lamar evm (K2L) board is added, so update Keystone2 readme file to have such one. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05board: k2l_evm: add network supportHao Zhang
This patch adds network support code and enables keystone_net driver usage for k2l_evm evaluation board. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-11-05am335x_evm: Convert NOR_BOOT to KconfigTom Rini
2014-11-05am335x_evm: Add NOR to KconfigTom Rini
Make enabling support for NOR (and describe where it's seen) be done via Kconfig. Signed-off-by: Tom Rini <trini@ti.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-10-23dm: omap3: Move to driver model for GPIO and serialSimon Glass
Adjust the configuration for the am33xx boards, including beagleboard, to use driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-10-23am335x_boneblack: Only modify NAND/NOR/MMC1 pinmux on BBB in boneblack builds.Tom Rini
In the case of Beaglebone Black we only want to set the NAND or NOR cape pinmux when the config has been specifically modified by the user for this non-default case. Make the default be to set the MMC1 (eMMC) pinmux. We don't need similar changes for Beaglebone White as there is nothing on MMC1 by default there. Signed-off-by: Tom Rini <trini@ti.com>
2014-10-23keystone2: ecc: add ddr3 error detection and correction supportVitaly Andrianov
This patch adds the DDR3 ECC support to enable ECC in the DDR3 EMIF controller for Keystone II devices. By default, ECC will only be enabled if RMW is supported in the DDR EMIF controller. The entire DDR memory will be scrubbed to zero using an EDMA channel after ECC is enabled and before u-boot is re-located to DDR memory. An ecc_test environment variable is added for ECC testing. If ecc_test is set to 0, a detection of 2-bit error will reset the device, if ecc_test is set to 1, 2-bit error detection will not reset the device, user can still boot the kernel to check the ECC error handling in kernel. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23board: k2e_evm: add network supportHao Zhang
This patch adds network support code and enables keystone_net driver usage for k2e_evm evaluation board. Acked-by: Vitaly Andrianov <vitalya@ti.com> Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23ARM: keystone: clock: add support for K2E SoCsKhoronzhuk, Ivan
For K2E and K2L SoCs clock output from PASS PLL has to be enabled after NETCP domain and PA module are enabled. So create new function for that and call it after PA module is enabled. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23net: keystone_net: remove redundant code from keystone_net.cKhoronzhuk, Ivan
Remove unused tx_send_loop variable. Removes duplicated get_link_status() call from the keystone2_eth_send_packet(). The emac_gigabit_enable() is called at opening Ethernet and there is no need to enable it on sending each packet. So remove that call from keystone2_eth_send_packet() as well. The calling of power/clock up functions are mostly the responsibility of SoC/board code, so move these functions to appropriate place. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23net: keystone_net: move header file from arch to ti-commonKhoronzhuk, Ivan
The header file for the driver should be in correct place. So move it to "arch/arm/include/asm/ti-common/keystone_net.h" and correct driver's external dependencies. At the same time align and correct some definitions. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23keystone2: k2l-evm: add board supportHao Zhang
This patch adds Keystone II Lammar (K2L) EVM board support. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23ARM: keystone2: spl: move board specific codeHao Zhang
The initialization of PLLs is a part of board specific code, so move it appropriate places. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-10ks2_evm: readme: align according to actual sourcesKhoronzhuk, Ivan
Update readme file for Keystone II EVM boards to actual sources. Also correct some typos. For now the Edison evaluation board is added, README for K2E is mostly the same, so update README to contain information also for K2E evm. Rename file to README as it contains information for all keystone evm boards. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-10beagleboard: Remove side effects of i2c2 pullup resisters initialization codeAlexander Kochetkov
Fix typo of commit d4e53f063dd25e071444b87303573e7440deeb89. i2c2 pullup resisters are controlled by bit 0 of CONTROL_PROG_IO1. It's value after reset is 0x00100001. In order to clear bit 0, original code write 0xfffffffe to CONTROL_PROG_IO1 and toggle almost all default values. Original code affect following: * disable i2c1 pullup resisters * increase far end load setting for many modules * setup invalid SC/LB combination Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com> CC: Tom Rini <trini@ti.com> CC: Steve Kipisz <s-kipisz2@ti.com>
2014-10-10OMAP5+: sata/scsi: Implement scsi_init()Roger Quadros
On OMAP platforms, SATA controller provides the SCSI subsystem so implement scsi_init(). Get rid of the unnecessary sata_init() call from dra7xx-evm and omap5-uevm board files. Signed-off-by: Roger Quadros <rogerq@ti.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
