path: root/board/ti
2016-03-15efi_loader: Add runtime servicesAlexander Graf
After booting has finished, EFI allows firmware to still interact with the OS using the "runtime services". These callbacks live in a separate address space, since they are available long after U-Boot has been overwritten by the OS. This patch adds enough framework for arbitrary code inside of U-Boot to become a runtime service with the right section attributes set. For now, we don't make use of it yet though. We could maybe in the future map U-boot environment variables to EFI variables here. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-15omap-common: Rename set_muxconf_regs_essential to set_muxconf_regsPaul Kocialkowski
There is no distinction between essential and non-essential mux configuration, so it doesn't make sense to have an "essential" prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap_hsmmc: Board-specific TWL6030 MMC power initializationPaul Kocialkowski
Boards using the TWL6030 regulator may not all use the LDOs the same way. Some might also not use MMC1 at all, so VMMC would't have to be enabled. This delegates TWL6030 MMC power initializations to board-specific functions, that may still call twl6030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-14ARM: DRA72-evm: Update mux and VIRTUAL/MANUAL mode timingsLokesh Vutla
All the mux configurations needs to be done as part of the IODelay sequence to avoid glitch. Adding all the mux configuration, MANUAL/VIRTUAL mode configuration as needed for DRA72-evm. Also update the mux for SD card detect on DRA74-evm. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: DRA7-evm: Update memory info in banksLokesh Vutla
Updating the memory banks properly so that DT is populated accordingly. And updating this only after DDR is properly detected by eeprom, so that git bisect is still maintained. Acked-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-03-14ARM: DRA7: EMIF: Add 4GB DDR settingsLokesh Vutla
The REVH and later versions of DRA7-evm uses MICRON MT41K512M16HA-125 memory chips which is of size 4GB(2GB on EMIF1 and 2GB on EMIF2). Add support for the same. Acked-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-03-14ARM: DRA7: Move emif settings to board specific filesLokesh Vutla
The newer versions of DRA7 boards has EEPROM populated with DDR size specified in it. Moving DRA7 specific emif related settings to board files so that emif settings can be identified based on EEPROM. Acked-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-03-14ARM: DRA7: Enable EEPROM supportLokesh Vutla
Enable EEPROM support for DRA74-evm. Acked-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-03-14ti: common: dra7: Add standard access for board description EEPROMLokesh Vutla
DRA7 EVM revH and later EVMs have EEPROM populated that can contain board description information such as name, revision, DDR definition, etc. Adding support for this EEPROM format. Acked-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-03-14ARM: AM57xx: Update EMIF registersLokesh Vutla
There are certain EMIF timing failures seen on the some x15 boards. Updating the EMIF settings to get rid of these timing failures. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-03-14ARM: Various: Future-proof serial platdataAdam Ford
A few boards still use ns16550_platdata structures, but assume the structure is going to be in a specific order. By explicitly naming each entry, this should also help 'future-proof' in the event the structure changes. Tested on the Logic PD Torpedo + Wireless. I only changed a handful of devices that used the same syntax as the Logic board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods and Alexander Graf. Signed-off-by: Adam Ford <aford173@gmail.com> V6: Add fix to arch/arm/cpu/armv7/am33xx/board.c V5: Add fix to arch/arm/cpu/arm926ejs/lpc32xx/devices.c V4: Fix subject heading V3: Remove reg_offset out in all the structs. It was reverted out, and and if it did exist, it would get initialized to 0 by default. V2: I hastily copy-pasted the boards without looking at the UART number. This addresses 3 boards that use UART3 and not UART1. Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-14ARM: keystone2: use detected ddr3a sizeVitaly Andrianov
Because KS2 u-boot works in 32 bit address space the existing ram_size global data field cannot be used. The maximum, which the get_ram_size() can detect is 2GB only. The ft_board_setup() needs the actual ddr3 size to fix up dtb. This commit introduces the ddr3_get_size() which uses SPD data to calculate the ddr3 size. This function replaces the "ddr3_size" environment variable, which was used to get the SODIMM size. For platforms, which don't have SODIMM with SPD and ddr3 is populated to a board a simple ddr3_get_size function that returns ddr3 size has to be implemented. See hardware-k2l.h Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: keystone2: use SPD info to configure K2HK and K2E DDR3Vitaly Andrianov
This commit replaces hard-coded EMIF and PHY DDR3 configurations for predefined SODIMMs to a calculated configuration. The SODIMM parameters are read from SODIMM's SPD and used to calculated the configuration. The current commit supports calculation for DDR3 with 1600MHz and 1333MHz only. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: keystone2: K2G: Add support for different arm/device speedsLokesh Vutla
The maximum device and arm speeds can be determined by reading EFUSE_BOOTROM register. As there is already a framework for reading this register, adding support for all possible speeds on k2g devices. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: keystone2: Allow for board specific speed definitionsLokesh Vutla
Its not compulsory that speed definition should be same on EFUSE_BOOTROM register for all keystone 2 devices. So, allow for board specific speed definitions. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14board: ti: AM57xx: Add detection logic for AM57xx-evmKipisz, Steven
Current AM57xx evm supports both BeagleBoard-X15 (http://beagleboard.org/x15) and AM57xx EVM (http://www.ti.com/tool/tmdxevm5728). The AM572x EValuation Module(EVM) provides an affordable platform to quickly start evaluation of Sitara. ARM Cortex-A15 AM57x Processors (AM5728, AM5726, AM5718, AM5716) and accelerate development for HMI, machine vision, networking, medical imaging and many other industrial applications. This EVM is based on the same BeagleBoard-X15 Chassis and adds mPCIe, mSATA, LCD, touchscreen, Camera, push button and TI's wlink8 offering. Since the EEPROM contents are compatible between the BeagleBoard-X15 and the AM57xx-evm, we add support for the detection logic to enable support for various user programmable scripting capability. NOTE: U-boot configuration is currently a superset of AM57xx evm and BeagleBoard-X15 and no additional configuration tweaking is needed. This change also sets up the stage for future support of TI AM57xx EVMs to the same base bootloader build. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ti: AM437x: Use generic EEPROM detection logicNishanth Menon
Now that we have a generic TI eeprom logic which can be reused across platforms, reuse the same. This revision also includes fixes identified by Dave Gerlach <d-gerlach@ti.com> Cc: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Steven Kipisz <s-kipisz2@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ti: AM335x: Use generic EEPROM detection logicNishanth Menon
Use the generic EEPROM detection logic instead of duplicating the AM eeprom logic. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Steven Kipisz <s-kipisz2@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: omap-common: Add standard access for board description EEPROMLokesh Vutla
Several TI EVMs have EEPROM that can contain board description information such as revision, DDR definition, serial number, etc. In just about all cases, these EEPROM are on the I2C bus and provides us the opportunity to centralize the generic operations involved. The on-board EEPROM on the BeagleBone Black, BeagleBone, AM335x EVM, AM43x GP EVM, AM57xx-evm, BeagleBoard-X15 share the same format. However, DRA-7* EVMs, OMAP4SDP use a modified format. We hence introduce logic which is generic between these platforms without enforcing any specific format. This allows the boards to use the relevant format for operations that they might choose. This module will compile for all TI SoC based boards when CONFIG_TI_I2C_BOARD_DETECT is enabled to have optimal build times for platforms that require this support. It is important to note that this logic is fundamental to the board configuration process such as DDR configuration which is needed in SPL, hence cannot be part of the standard u-boot driver model (which is available later in the process). Hence, to aid efficiency, the eeprom contents are copied over to SRAM scratchpad memory area at the first invocation to retrieve data. To prevent churn with cases such as DRA7, where eeprom format maybe incompatible, we introduce a generic common format in eeprom which is made available over accessor functions for usage. Special handling for BBG1 EEPROM had to be introduced thanks to the weird eeprom rev contents used. The follow on patches introduce the use of this library for AM335x, AM437x, and AM57xx. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-15ARM : DRA7: Switch QSPI to use MODE-0 at 64MHzVignesh R
According to Data Manual(SPRS915P) of AM572x, TI QSPI controller on DRA74 EVM(rev 1.1+) can support up to 64MHz in MODE-0, whereas MODE-3 is limited to 48MHz. Hence, switch to MODE-0 for better throughput. Also, add IODelay parameters for the same. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08board: ti: ks2_evm: remove board_eth_init when CONFIG_DM_ETH is definedMugunthan V N
remove board_eth_init when CONFIG_DM_ETH is defined Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-21ARM: dra7x/am57x: Remove pin input/output config from WAKEUP pinsCooper Jr., Franklin
The WAKEUP_X pins are always an input no matter the pinmux mode. However, the 18th bit that typical configures a pin as an input is considered reserved for the WAKEUP_X pins. Therefore, for any WAKEUP pin remove any configuration that sets that pin as an input. Since those pins are only inputs remove any output configuration from those pins. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-18board/ti/am335x: add support for BeagleBone Greenrobertcnelson@gmail.com
SeeedStudio BeagleBone Green (BBG) is clone of the BeagleBone Black (BBB) minus the HDMI port and addition of two Grove connectors (i2c2 and usart2). This board can be identified by the 1A value after A335BNLT (BBB) in the at24 eeprom: 1A: [aa 55 33 ee 41 33 33 35 42 4e 4c 54 1a 00 00 00 |.U3.A335BNLT....|] http://beagleboard.org/green http://www.seeedstudio.com/wiki/Beaglebone_green In Mainline Kernel as of: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=79a4e64c679d8a0b1037da174e4aea578c80c4e6 Patch tested on BeagleBone Black (rev C) and BeagleBone Green (production model) Signed-off-by: Robert Nelson <robertcnelson@gmail.com> CC: Tom Rini <trini@konsulko.com> CC: Jason Kridner <jkridner@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-18board: ti: beagle_x15: Rename to indicate support for TI am57xx evmsKipisz, Steven
BeagleBoard X15 (http://beagleboard.org/x15) support in u-boot does actually support two different platform configuration offered by TI. In addition to BeagleBoard X15, it also supports the TMDXEVM5728 (or more commonly known as AM5728-evm). Information about the TI AM57xx EVM can be found here http://www.ti.com/tool/tmdxevm5728 The EVM configuration is 1-1 compatible with BeagleBoard X15 with the additional support for mPCIe, mSATA, LCD, touchscreen, Camera, push button and TI's wlink8 offering. Hence, we rename the beagle_x15 directory to am57xx to support TI EVMs that use the AM57xx processor. By doing this we have common code reuse. This sets the stage to have a common u-boot image solution for multiple TI EVMs such as that already done for am335x and am437x. This sets the stage for upcoming multiple TI EVMs that share the same code base. NOTE: Commit eae7ae185335 ("am437x: Add am57xx_evm_defconfig using CONFIG_DM") introduced DT support for beagle_x15 under am57xx_evm platform name. However, this ignored the potential confusion arising for users as a result. To prevent this, existing beagle_x15_defconfig is renamed as am57xx_evm_nodt_defconfig to denote that this is the "non device tree" configuration for the same platform. We still retain am57xx-beagle-x15.dts at this point, since we just require the common minimum dts. As a result of this change, users should expect changes in build procedures('make am57xx_evm_nodt_defconfig' instead of 'make beagle_x15_defconfig'). Hopefully, this would be a one-time change. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Schuyler Patton <spatton@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-11-12board/ti/am335x: beaglebone stop muxing i2c1_pin_muxrobertcnelson@gmail.com
On the BeagleBone these i2c1 pins are routed to the expanasion header, where they can be defined as either pr1_usart0_Xxd/pwm0/spi0/i2c1, dont assume i2c1 Fixes: https://e2e.ti.com/support/arm/sitara_arm/f/791/p/313894/1387696 Signed-off-by: Robert Nelson <robertcnelson@gmail.com> Reported-by: Matthijs van Duin <matthijsvanduin@gmail.com> CC: Tom Rini <trini@konsulko.com>
2015-11-10board/ti: Update MAINTAINERS entries with more boardsTom Rini
A few config files have been added without updating MAINTAINERS. Reported-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-22ARM: AM335x: mux: change mmc0 cd pinmux from mmc0_sdcd to gpioMugunthan V N
Currently omap_hsmmc driver doesn't use sdcd pin to detect whether the card is present or not. Instead the same pin is used as GPIO to detect card presence. So change the pin mux mode from mmc0_sdcd to gpio0_6. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22ARM: k2g: Add config fileLokesh Vutla
Add config file for k2g Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
2015-10-22ARM: k2g: Enable SPI flashLokesh Vutla
GPIO1_9 controls SPI flash on k2g evm. So make GPIO1_9 as output pin, inorder to use SPI. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: add SD card and eMMC supportRoger Quadros
Add MMC support for k2g Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-10-22ARM: k2g: Add Ethernet SupportVitaly Andrianov
Add Ethernet support for tftp support Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22driver: net: keystone_net: fix phy mode configurationMugunthan V N
Phy mode is a board property and it can be different between multiple board and ports, so it should not be hardcoded in driver to one specific mode. So adding a field in eth_priv_t structure to pass phy mode to driver. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add pin mux dataVitaly Andrianov
Add pin mux data for k2g-evm Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add ddr3 infoVitaly Andrianov
Add ddr3 related info Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add clock informationVitaly Andrianov
Add clock information for Galileo Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-10-22ARM: k2g: Add pll dataVitaly Andrianov
Add pll data for k2g Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add kconfig supportLokesh Vutla
Add Kconfig support Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: keystone2: Use dtb images by defaultLokesh Vutla
Now that OF_CONTROL is enabled on all keystone2 platforms, build the default images with DT. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22am335x_evm: prepare for eth driver model supportMugunthan V N
Prepare board file so that ethernet registration are commented for DM conversion Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap-common: Common serial and usbethaddr functions based on die idPaul Kocialkowski
Now that we have a common prototype to grab the omap die id, functions to figure out a serial number and usb ethernet address can use it directly. Those also get an omap_die_id prefix for better consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap5: omap_die_id supportPaul Kocialkowski
This introduces omap5 support for omap_die_id, which matches the common omap_die_id definition. It replaces board-specific code to grab the die id bits. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap4: omap_die_id supportPaul Kocialkowski
This introduces omap4 support for omap_die_id, which matches the common omap_die_id definition. It replaces board-specific code to grab the die id bits. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap3: omap_die_id supportPaul Kocialkowski
This replaces the previous get_dieid definition with omap_die_id, that matches the common omap_die_id definition. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22ARM Fix pandaboard es and a4 revision IDdbatzle@dcbcyber.com
board_name environment variable was not getting set correctly for Pandaboard A4 and ES Signed-off-by: David Batzle <dbatzle@dcbcyber.com> CC: Albert Aribaud <albert.u.boot@aribaud.net>; Tom Rini <trini@ti.com>; Peter Robinson <pbrobinson@gmail.com>
2015-10-17ARM: k2e/l: Apply WA for selecting PA clock sourceLokesh Vutla
On keystone2 Lamarr and Edison platforms, the PA clocksource mux in PLL REG1, can be changed only after enabling its clock domain. So selecting the output of PASS PLL as input to PA only after enabling the clockdomain. This is as per the debug done by "Vitaly Andrianov <vitalya@ti.com>" and based on the previous work done by "Hao Zhang <hzhang@ti.com>" Fixes: d634a0775bcf ("ARM: keystone2: Cleanup PLL init code") Reported-by: Vitaly Andrianov <vitalya@ti.com> Tested-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-09-15ti816x: Switch to SYS_GENERIC_BOARDTom Rini
Tested on my TI186x rev E. (PG2.0) and take over maintainership. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-09-15ti814x_evm: Switch to SYS_GENERIC_BOARDTom Rini
Take over maintainership as well. Not tested as PG2.0 (which I have) needs additional work over PG1.0 (which Matt has). Cc: Matt Porter <mporter@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
