path: root/board/ti/sdp4430
2011-12-06omap4460: fix TPS initializationAneesh V
TPS power IC is controlled using a GPIO (gpio_wk7). This GPIO should be maintained at logic 1 always. As such an internal pull-up on this pin will do the job, driving the GPIO outuput is not needed. This will avoid the need of using GPIO library in SPL and also may save some power. Signed-off-by: Aneesh V <aneesh@ti.com>
2011-11-15omap4/5: Add support for booting with CH.Sricharan
Configuration header(CH) is 512 byte header attached to an OMAP boot image that will help ROM code to initialize clocks, SDRAM etc and copy U-Boot directly into SDRAM. CH can help us in by-passing SPL and directly boot U-boot, hence it's an alternative for SPL. However, we intend to support both CH and SPL for OMAP4/5. Initialization done through CH is limited and is not equivalent to that done by SPL. So U-Boot has to distinguish between the two cases and handle them accordingly. This patch takes care of doing this. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-15omap5: Add minimal support for omap5430.Sricharan
This patch adds the minimal support for OMAP5. The platform and machine specific headers and sources updated for OMAP5430. OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture. It's a dual core SOC with GIC used for interrupt handling and SCU for cache coherency. Also moved some part of code from the basic platform support that can be made common for OMAP4/5. Rest is kept out seperately. The same approach is followed for clocks and emif support in the subsequent patches. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap4: fix pad configuration settings for SDP and PandaAneesh V
omap4: fix pad configuration settings for SDP and Panda Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sebastien Jan <s-jan@ti.com> Signed-off-by: David Anders <x0132446@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03omap: add basic SPL supportAneesh V
- Provide alternate implementations of board_init_f() board_init_r() for OMAP spl. - Provide linker script - Initialize global data - Add serial console support - Update CONFIG_SYS_TEXT_BASE to allow for SPL's bss and move it to board config header from config.mk Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03omap4: cleanup pin mux dataAneesh V
- separate mux settings into essential and non essential parts - essential part is board independent as of now(so move it to SoC directory). Will help in having single SPL for all boards. - Non-essential part(the pins not essential for u-boot to function) need to be phased out eventually. - Correct mux data by aligning to the latest settings in x-loader Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-12-11ARMV7: OMAP4: twl6030 add battery charging supportBalaji T K
Add battery charging support twl6030 driver. Add support for battery voltage and current measurements. Add command to get battery status and start/stop battery charging from USB. Signed-off-by: Balaji T K <balajitk@ti.com> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17ARMV7: OMAP4: Implement relocation for Panda and OMAP4430SDPSteve Sakoman
This patch fixes the build breakage introduced by the recent relocation changes for ARMV7 Signed-off-by: Steve Sakoman <steve@sakoman.com>
2010-10-17ARMV7: OMAP4: Use generic mmc driver on SDP4430Sukumar Ghorai
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Tested-by: Steve Sakoman <steve@sakoman.com>
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-05ARMV7: Add pad mux support for OMAP4Steve Sakoman
Add functional multiplexing support for OMAP4 pads. Configure all the pads for the OMAP4430 SDP and OMAP4 Panda boards Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-15ARMV7: Add basic gpmc initialization for OMAP4Steve Sakoman
This patch adds a gpmc_init function for OMAP4 and adds calls to gpmc_init for existing OMAP4 boards: panda and sdp4430 Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Add support for TI OMAP4430 SDPSteve Sakoman
OMAP4430 SDP is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
