path: root/board/ti/panda
2010-10-17ARMV7: OMAP4: Implement relocation for Panda and OMAP4430SDPSteve Sakoman
This patch fixes the build breakage introduced by the recent relocation changes for ARMV7 Signed-off-by: Steve Sakoman <steve@sakoman.com>
2010-10-17ARMV7: OMAP4: Use generic mmc driver on PandaSukumar Ghorai
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Tested-by: Steve Sakoman <steve@sakoman.com>
2010-09-28ARMV7: OMAP4: Fix Panda pinmux setting to enable Wifi/BT ModuleSteve Sakoman
This patch corrects the pinmux settings to enable proper functioning of the wifi/bluetooth module. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-08ARMV7: Fix pad mux for Panda LEDsRicardo Salveti de Araujo
Correctly set PAD1_FREF_CLK4_REQ and PAD0_FREF_CLK4_OUT to enable and activate both LEDs while setting pad mux. Since this increases the line length, this patch also adjusts the white space in this section of code to allign the pad mux signal description comments. Signed-off-by: Ricardo Salveti de Araujo <ricardo.salveti@canonical.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Add pad mux support for OMAP4Steve Sakoman
Add functional multiplexing support for OMAP4 pads. Configure all the pads for the OMAP4430 SDP and OMAP4 Panda boards Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-15ARMV7: Add basic gpmc initialization for OMAP4Steve Sakoman
This patch adds a gpmc_init function for OMAP4 and adds calls to gpmc_init for existing OMAP4 boards: panda and sdp4430 Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Add support for TI OMAP4 PandaSteve Sakoman
OMAP4 Panda is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
