path: root/board/ti/omap2420h4
2013-04-08omap2420-h4: Fix booting from NOR flashHunter, Jon
The omap2420-h4 board is using a RAM based address as the linker location for code. This is causing several problems when attempting to run the latest u-boot code base on this board from flash. Update the default linker location for code to be in NOR flash. Please note that OMAP maps the NOR flash to address 0x08000000 by default and so use this as the default address for the NOR flash. Also remove legacy code that attempts to calculate where in flash the sdata structure, that holds the memory interface configuration data, is located. By changing the default linker location for code to flash this is no longer necessary. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-08omap2420-h4: Fix DRAM initialisationHunter, Jon
The size of the DRAM for the omap2420-h4 board is getting setup in the dram_init() function. However, for the current u-boot release this is too late and needs to be done in dram_init_banksize(). Therefore, add a dram_init_banksize() function for the omap2420-h4 board and setup the DRAM size there. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2012-10-22omap2424:Rename CONFIG_DRIVER_LAN91C96 to CONFIG_LAN91C96 as ↵Ashok
CONFIG_DRIVER_LAN91C96 is obsolete. Rename CONFIG_DRIVER_LAN91C96 to CONFIG_LAN91C9 as CONFIG_DRIVER_LAN91C96 is obsolete. Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
2011-12-12board/ti/omap2420h4/omap2420h4.c: Fix GC 4.6 build warningWolfgang Denk
Fix: omap2420h4.c: In function 'dram_init': omap2420h4.c:196:25: warning: variable 'cpu' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Richard Woodruff <r-woodruff2@ti.com> Cc: Tom Rini <trini@ti.com>
2009-12-14Net: Clean up LAN91C96 SupportBen Warren
A previous Commit converted the LAN91C96 Ethernet driver to using the CONFIG_NET_MULTI API, but did not include full board support. This patch finishes the job. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-05omap: move TI's boards to board/ti/Jean-Christophe PLAGNIOL-VILLARD
