The omap2420H4 was the only mainline omap24xx board. Prior to being
fixed by Jon Hunter in time for v2013.04 it had been functionally broken
for a very long time. Remove this board as there's not been interest in
it in U-Boot for quite a long time.
To be consistent with other ARM platforms,
renaming asm/arch-omap*/clocks.h to asm/arch-omap*/clock.h
The omap2420-h4 board is using a RAM based address as the linker
location for code. This is causing several problems when attempting
to run the latest u-boot code base on this board from flash. Update
the default linker location for code to be in NOR flash. Please note
that OMAP maps the NOR flash to address 0x08000000 by default and so
use this as the default address for the NOR flash.
Also remove legacy code that attempts to calculate where in flash the
sdata structure, that holds the memory interface configuration data,
is located. By changing the default linker location for code to flash
this is no longer necessary.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
The size of the DRAM for the omap2420-h4 board is getting setup in the
dram_init() function. However, for the current u-boot release this is
too late and needs to be done in dram_init_banksize(). Therefore, add
a dram_init_banksize() function for the omap2420-h4 board and setup the
DRAM size there.
CONFIG_DRIVER_LAN91C96 is obsolete.
Rename CONFIG_DRIVER_LAN91C96 to CONFIG_LAN91C9 as
Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
Under option -munaligned-access, gcc can perform local char
or 16-bit array initializations using misaligned native
accesses which will throw a data abort exception. Fix files
where these array initializations were unneeded, and for
files known to contain such initializations, enforce gcc
option -mno-unaligned-access.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
[trini: Switch to usign call cc-option for -mno-unaligned-access as
Albert had done previously as that's really correct]
Fix:
omap2420h4.c: In function 'dram_init':
omap2420h4.c:196:25: warning: variable 'cpu' set but not used
[-Wunused-but-set-variable]
Cc: Richard Woodruff <r-woodruff2@ti.com>
Cc: Tom Rini <trini@ti.com>
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
A previous Commit converted the LAN91C96 Ethernet driver to using the
CONFIG_NET_MULTI API, but did not include full board support. This patch
finishes the job.
