path: root/board/ti/omap1610inn
2009-12-14Net: Clean up LAN91C96 SupportBen Warren
A previous Commit converted the LAN91C96 Ethernet driver to using the CONFIG_NET_MULTI API, but did not include full board support. This patch finishes the job. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-05omap: move TI's boards to board/ti/Jean-Christophe PLAGNIOL-VILLARD
