path: root/board/ti/ks2_evm/ddr3_cfg.c
2016-03-14ARM: keystone2: use SPD info to configure K2HK and K2E DDR3Vitaly Andrianov
This commit replaces hard-coded EMIF and PHY DDR3 configurations for predefined SODIMMs to a calculated configuration. The SODIMM parameters are read from SODIMM's SPD and used to calculated the configuration. The current commit supports calculation for DDR3 with 1600MHz and 1333MHz only. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-10-23keystone2: k2l-evm: add board supportHao Zhang
This patch adds Keystone II Lammar (K2L) EVM board support. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25board: k2e-evm: add board supportHao Zhang
This patch adds Keystone2 k2e_evm evaluation board support. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25keystone: ddr3: move K2HK DDR3 configuration to a common fileHao Zhang
It's convenient to hold configurations for DDR3 PHY and EMIF in separate common place. This patch moves K2HK DDR3 PHY and EMIF configuration data with different rates and memory size to a common ddr3_cfg.c file. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
