path: root/board/ti/j721s2/evm.c
10 daysMerge tag '09.02.00.010' into toradex_ti-u-boot-2023.04Max Krummenacher
RC Release 09.02.00.010 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-05-03board: ti: j7: evm.c: Propagate DT fixup in A72 SPL for enabled ECCNeha Malcom Francis
Call fixup_memory_node() in A72 SPL stage so that the memory changes made by fixup_ddr_driver_for_ecc() by R5 SPL is propagated to the A72 U-Boot stage as well. Fixes: 410888e38c7e ("board: ti: Pull redundant DDR functions to a common location and Fixup DDR size when ECC is enabled") Signed-off-by: Neha Malcom Francis <n-francis@ti.com>
2024-04-25board: ti: Fix call to fdt_fixup_msmc_ramEmanuele Ghidoli
Substitute failing calls to fdt_fixup_msmc_ram function by calling fdt_fixup_msmc_ram_k3 function which was implemented in commit [1]. At functional level nothing changes. [1] b6e669d7a393 ("arm: k3: Fix ft_system_setup so it can be enabled on any SoC") Upstream-Status: Inappropriate Commit [1] is already upstreamed and the new function is already used when new boards were added. Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
2024-03-21board: ti: j721s2: Move order of AVS probingUdit Kumar
AVS driver was getting probed with base device tree, which leads i2c of derivative board (AM68) in bad state. Moving AVS probe after detection of right device tree. Fixes: eaa184009775 ("arm: k3: j721s2: Enable AVS") Reported-by: Minas Hambardzumyan <minas@ti.com> Cc: Manorit Chawdhry <m-chawdhry@ti.com> Cc: Vignesh Raghavendra <vigneshr@ti.com> Cc: Praneeth Bajjuri <praneeth@ti.com> Signed-off-by: Udit Kumar <u-kumar1@ti.com>
2024-03-21board: ti: Pull redundant DDR functions to a common location and Fixup DDR ↵Santhosh Kumar K
size when ECC is enabled As there are few redundant functions in board/ti/*/evm.c files, pull them to a common location of access to reuse and include the common file to access the functions. Call k3-ddrss driver through fixup_ddr_driver_for_ecc() to fixup the device tree and resize the available amount of DDR, if ECC is enabled. Otherwise, fixup the device tree using the regular fdt_fixup_memory_banks(). Modify fixup_ddr_driver_for_ecc() to make the function agnostic to the number of DDR controllers present. Signed-off-by: Santhosh Kumar K <s-k6@ti.com> Signed-off-by: Neha Malcom Francis <n-francis@ti.com>
2024-02-15board: ti: j721s2: Move order of AVS probingUdit Kumar
2024-02-14board: ti: Pull redundant DDR functions to a common location and Fixup DDR ↵Santhosh Kumar K
2023-10-09board: ti: j721s2: Initialize the ESM & PMIC ESMKeerthy
Initialize the 3 instances of SOC ESM & PMIC ESM. This is needed for watchdog functionality. Signed-off-by: Keerthy <j-keerthy@ti.com>
2023-10-07board: ti: j721s2: Add cadence-qspi flash node selectionApurva Nandan
Add cadence-qspi flash node selection for choosing between OSPI NOR and OSPI NAND flashes put under OSPI0 instance. This is needed for R5 SPL as it is not possible to apply fixup at this stage. Signed-off-by: Apurva Nandan <a-nandan@ti.com>
2023-10-07board: ti: j721s2: Use IS_ENABLED in place of #ifApurva Nandan
IS_ENABLED is the recommendation for checking CONFIG flags. Use it instead of #if, and drop redundant checking of DM_GPIO and OF_LIBFDT. #if defined(CONFIG_SPL_BUILD) can't be removed from spl_perform_fixups, as it results in compile error. Signed-off-by: Apurva Nandan <a-nandan@ti.com>
2023-10-07board: ti: j721s2: Delete nodes for OSPI NAND SPL fixupApurva Nandan
cadence-qspi manually parses flash subnodes. Simply disabling the node was not giving expected behaviour across drivers. So, additionally delete the disabled node also as the flash is undiscoverable due to hardware muxing anyways. Signed-off-by: Apurva Nandan <a-nandan@ti.com>
2023-06-08board: ti: j721s2: Enable OSPI NAND SPL fixupApurva Nandan
On J721S2, SW3.1 (WKUP_GPIO0_6) is used for selecting between OSPI NOR and OSPI NAND flash. Read the GPIO state, to perform correct enable/disable operation on the fdt, for a valid flash discovery. Signed-off-by: Apurva Nandan <a-nandan@ti.com> Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2023-06-08board: ti: j721s2: Add support to detect daughtercardsKishon Vijay Abraham I
commit 7bf341ae4dfb3f126323cd906efe37e46851c9fa upstream. Add support to detect daughtercards (GESI Ethernet card) in-order to set the MAC address of the main CPSW2G interface. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Siddharth Vadapalli <s-vadapalli@ti.com>
2023-01-27board: ti: j721s2: Add board_init and support for selecting DT based on EEPROMSinthu Raja
Add the board_init_f API for SPL and run the platform-required SoC initialization. Add the functionality for board name-based DTB selection from FIT within SPL. This will make it easier to utilise one defconfig for both the EVM and the SK. Signed-off-by: Sinthu Raja <sinthu.raja@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2023-01-27board: ti: j721s2: Add support for detecting multiple device treesSinthu Raja
Update the board_fit_config_name_match() to choose the right dtb based on the board name read from EEPROM. Also restrict multpile EEPROM reads by verifying if EEPROM is already read Signed-off-by: Sinthu Raja <sinthu.raja@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2023-01-27board: ti: j721s2: Enable support for reading EEPROM at next alternate addressSinthu Raja
J721S2 EVM has EEPROM populated at 0x50. AM68 SK has EEPROM populated at next address 0x51 in order to be compatible with RPi. So start looking for TI specific EEPROM at 0x50, if not found look for EEPROM at 0x51. Signed-off-by: Sinthu Raja <sinthu.raja@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2023-01-27board: ti: j721s2: Add support to update board_name for am68-skSinthu Raja
Update setup_board_eeprom_env() to choose the right board name for am68-sk. Signed-off-by: Sinthu Raja <sinthu.raja@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2022-12-05global: Move remaining CONFIG_SYS_SDRAM_* to CFG_SYS_SDRAM_*Tom Rini
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM namespace do not easily transition to Kconfig. In many cases they likely should come from the device tree instead. Move these out of CONFIG namespace and in to CFG namespace. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-09-23board_f: Fix types for board_get_usable_ram_top()Pali Rohár
Commit 37dc958947ed ("global_data.h: Change ram_top type to phys_addr_t") changed type of ram_top member from ulong to phys_addr_t but did not changed types in board_get_usable_ram_top() function which returns value for ram_top. So change ulong to phys_addr_t type also in board_get_usable_ram_top() signature and implementations. Fixes: 37dc958947ed ("global_data.h: Change ram_top type to phys_addr_t") Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-02-08board: ti: j721s2: Add board support for J721S2David Huang
Add board support for J721S2 SoC. Signed-off-by: David Huang <d-huang@ti.com> Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
