path: root/board/ti/j721e
2020-08-11board: ti: j721e: Update fdt fixup logic for interconnect nodesSuman Anna
The DT nodes on J721E SoCs currently use a node name "interconnect" for the various interconnects. This name is not following the DT schema, and should simply be "bus". Update the fdt fixup logic to use both the current and the expected corrected path names so that this logic won't be broken with newer kernels. Signed-off-by: Suman Anna <s-anna@ti.com>
2020-08-11board: ti: j721e: Probe eeprom only when CONFIG_TI_I2C_BOARD_DETECT is definedLokesh Vutla
Guard all eeprom probe with TI_I2C_BOARD_DETECT to avoid reading eeprom when eeprom is not available Reviewed-by: Suman Anna <s-anna@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-06-02arm: ti: Remove ARCH= references from documentationTom Rini
When building U-Boot we select the architecture via Kconfig and not ARCH being passed in via the environment or make cmdline. Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop image.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-03-06board: ti: README: Update OP-TEE binary nameAndrew F. Davis
The OP-TEE binary to use is renamed to v2 as the v1 binary has been deprecated and is no longer built by default. Reported-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com>
2020-03-03board: ti: k3: Update the sysfw image gen repositoryLokesh Vutla
Now k3-image-gen[0] is the official repository for generating sysfw.itb Update the same in AM65x and J721e README. [0] https://git.ti.com/cgit/k3-image-gen/k3-image-gen/ Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-03-03board: ti: j721e: initialize ESM supportTero Kristo
Initialize both ESM and ESM_PMIC support if available for the board. If support is not available for either, a warning is printed out. ESM signals are only properly routed on PM2 version of the J721E SOM, so only probe the drivers on this device. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2020-03-03board: ti: Update AM65x and J721e READMEs for OSPI bootVignesh Raghavendra
Update AM65x and J721e README files with instructions for flashing OSPI images. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2020-01-20board: ti: j721e: Print board name and version during bootLokesh Vutla
Print the board name and ver along with the DT Model. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20board: ti: j721e: Use EEPROM-based board detectionAndreas Dannenberg
The TI J721E EVM system on module (SOM), the common processor board, and the associated daughtercards have on-board I2C-based EEPROMs containing board config data. Use the board detection infrastructure to do the following: 1) Parse the J721E SOM EEPROM and populate items like board name, board HW and SW revision as well as board serial number into the TI common EEPROM data structure residing in SRAM scratch space 2) Check for presence of daughter card(s) by probing associated I2C addresses used for on-board EEPROMs containing daughter card-specific data. If such a card is found, parse the EEPROM data such as for additional Ethernet MAC addresses and populate those into U-Boot accordingly 3) Dynamically apply daughter card DTB overlays to the U-Boot (proper) DTB during SPL execution 4) Dynamically create an U-Boot ENV variable called name_overlays during U-Boot execution containing a list of daugherboard-specific DTB overlays based on daughercards found to be used during Kernel boot. This patch adds support for the J721E system on module boards containing the actual SoC ("J721EX-PM2-SOM", accessed via CONFIG_EEPROM_CHIP_ADDRESS), the common processor board ("J7X-BASE-CPB"), the Quad-Port Ethernet Expansion Board ("J7X-VSC8514-ETH"), the infotainment board ("J7X-INFOTAN-EXP") as well as for the gateway/Ethernet switch/industrial expansion board ("J7X-GESI-EXP"). Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-12-02common: Move board_get_usable_ram_top() out of common.hSimon Glass
Move this function into init.h which seems to be designed for this sort of thing. Also update the header to declare struct global_data so that it can be included without global_data.h being needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-25armv7R: K3: j721e: Add support for triggering ddr init from SPLLokesh Vutla
In SPL, DDR should be made available by the end of board_init_f() so that apis in board_init_r() can use ddr. Adding support for triggering DDR initialization from board_init_f(). Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11board: j721e: Add READMELokesh Vutla
Add README file explaining the build and boot procedure for J721E evm. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-07-26configs: j721e_evm_a72: Add initial supportLokesh Vutla
Add initial defconfig support for J721e that runs on A72. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Add MAINTAINERS entry] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-26configs: j721e_evm_r5: Add initial supportLokesh Vutla
Add initial defconfig support for J721e that runs on R5. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Add MAINTAINERS file] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-26board: ti: j721e: Enable fixing up msmc sram nodeSuman Anna
Create a ft_board_setup() api that gets called as part of DT fixup before jumping to kernel. In this ft_board_setup() call fdt_fixup_msmc_ram that update msmc sram node. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-07-26board: ti: j721e: Add board support for j721e evmLokesh Vutla
Add board specific initialization for j721e evm Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
