path: root/board/ti/evm
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-12-18OMAP3: EVM: Convert omap3_evm_version to u32Dirk Behme
Convert the variable omap3_evm_version to u32 to work around some broken linkers from older tool chains. E.g. CodeSourcery's 2009q1-203 ld 2.19.51.20090205. Without this, these linkers stop linking 'omap3_evm' or at least issue a warning. Like arm-none-linux-gnueabi-ld: section .bss [8003f5e0 -> 8007e337] overlaps section .rel.dyn [8003f5e0 -> 80044e57] arm-none-linux-gnueabi-ld: section .dynsym [80044e58 -> 80044ef7] overlaps section.bss [8003f5e0 -> 8007e337] arm-none-linux-gnueabi-ld: u-boot: section .bss vma 0x8003f5e0 overlaps previous sections CC: Sanjeev Premi <premi@ti.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2010-11-04omap3evm: Fix mechanism to identify board revisionSanjeev Premi
Function omap3_evm_get_revision() - to identify the board revision was called at end of setup_net_chip(). Board revision can be ascertained only by identifying the Ethernet chipset - but combining setup operations with revision detection isn't a good idea. So, moved the function after call to setup_net_chip(). Function setup_net_chip() should be ideally be called only when CONFIG_CMD_NET is defined. But this leaves the board revision "undetected". This patch allows static definition of revision or default fallback to the latest revision. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Wrap function under CONFIG_USB_OMAP3Sanjeev Premi
The function omap3_evm_need_extvbus() is required only when USB support is configured. Wrapped this function in #ifdef CONFIG_USB_OMAP3. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Support relocationSanjeev Premi
This patch adds relocation support for omap3evm. Content of the patch is based on changes for Beagleboard. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-30musb: Program extvbus for OMAP3EVM Rev >= EAjay Kumar Gupta
OMAP3EVM Rev >=E uses external Vbus supply so setting 'extvbus' to '1' for OMAP3EVM Rev >=E runtime based on EVM revision. CC: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
2010-06-30omap3evm: Add board revision functionAjay Kumar Gupta
Added function to differentiate between the OMAP3EVM revisions. The chip-id of the ethernet PHY is being used for this purpose. Rev A to D : 0x01150000 Rev >= E : 0x92200000 CC: Remy Bohmer <linux@bohmer.net> Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Acked-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-13OMAP3: Clean up whitespace in mux configsOlof Johansson
Switch from space-based indentation to tab-based in mux configs, as pointed out by WD at: http://lists.denx.de/pipermail/u-boot/2009-September/061241.html Nothing but whitespace changes in this patch (diff -w gives no output). Signed-off-by: Olof Johansson <olof@lixom.net>
2009-09-05omap: move TI's boards to board/ti/Jean-Christophe PLAGNIOL-VILLARD
