path: root/board/ti/evm/Kconfig
2016-08-05omap3: Drop omap3_evm_quick_* targetsTom Rini
These config targets were added well before the Kconfig migration began as a way to demonstrate how to make these platforms work with cut down features. At this point in time they no longer serve a good purpose so remove them. Signed-off-by: Tom Rini <trini@konsulko.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
