Current usage of eeprom apis produce a build failure when
CONFIG_TI_I2C_BOARD_DETECT is not defined. Add stub function for these
apis to avoid build failures.
Reviewed-by: Suman Anna <s-anna@ti.com>
Move this uncommon header out of the common header.
The TI J721E EVM system on module (SOM), the common processor board, and
the associated daughtercards have on-board I2C-based EEPROMs containing
board config data. Use the board detection infrastructure to do the
following:
1) Parse the J721E SOM EEPROM and populate items like board name, board
HW and SW revision as well as board serial number into the TI common
EEPROM data structure residing in SRAM scratch space
2) Check for presence of daughter card(s) by probing associated I2C
addresses used for on-board EEPROMs containing daughter card-specific
data. If such a card is found, parse the EEPROM data such as for
additional Ethernet MAC addresses and populate those into U-Boot
accordingly
3) Dynamically apply daughter card DTB overlays to the U-Boot (proper)
DTB during SPL execution
4) Dynamically create an U-Boot ENV variable called name_overlays
during U-Boot execution containing a list of daugherboard-specific
DTB overlays based on daughercards found to be used during Kernel
boot.
This patch adds support for the J721E system on module boards containing
the actual SoC ("J721EX-PM2-SOM", accessed via CONFIG_EEPROM_CHIP_ADDRESS),
the common processor board ("J7X-BASE-CPB"), the Quad-Port Ethernet
Expansion Board ("J7X-VSC8514-ETH"), the infotainment board
("J7X-INFOTAN-EXP") as well as for the gateway/Ethernet switch/industrial
expansion board ("J7X-GESI-EXP").
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
BeagleBoard.org BeagleBone AI rev A1 does not include a board
identifier I2C EEPROM due to a design oversight. These boards have
been put into production and are generally available now.
The board identifier information, however, has been included in the
second eMMC linear boot partition (/dev/mmcblk1boot1).
This patch works by:
* First, looking for a board identifier I2C EEPROM and if not found,
* Then seeing if the boot mode matches BeagleBone AI with eMMC in the
boot chain to make sure we don't enable eMMC pinmuxes on boards
that don't support it, and
* Finally, initializes the eMMC pins and reading the header.
Signed-off-by: Jason Kridner <jdk@ti.com>
Signed-off-by: Caleb Robey <c-robey@ti.com>
Cc: Robert Nelson <robertcnelson@gmail.com>
The AM654x EVM based on the TI K3 family of SoCs has an updated board
detection EEPROM structure that contains a TLV record of dedicated MAC
addresses rather than a range of MAC addresses as it was used on earlier
platforms such as DRA7. Add a basic function that allows us setting up
Ethernet MAC addresses into the U-Boot environment based on the MAC
address record contained in the common TI EEPROM structure.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
The AM654x EVM based on the TI K3 family of SoCs have an updated board
detection EEPROM structure, now comprising variable-sized TLV-type
records, containing a superset of what is already being provided on
earlier platforms such as DRA7. Add basic support for parsing the new
data structures contained on the base board into the common TI EEPROM
structure while also providing infrastructure that can be used later on
to parse data from additional EEPROMs such as the ones that are used on
daughtercards for this platform.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
When the EEPROM is first read its contents are stored in memory as a
cache to avoid further I2C operations. To determine if the EEPROM was
previously read the easiest way is to check the memory to see if the
EEPROM's magic header value is set. Create a new function that can
determine if the EEPROM was previously read or not without having to
perform a I2C transaction.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
In some situations the EEPROM used for board detection may not be
programmed or simply programmed incorrectly. Therefore, it may be
necessary to "simulate" reading the contents of the EEPROM to set
appropriate variables used in the board detection code.
This may also be helpful in certain boot modes where doing i2c reads
may be costly and the config supports running only a specific board.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Keerthy <j-keerthy@ti.com>
Signed-off-by: Franklin S Cooper Jr. <fcooper@ti.com>
Keystone and OMAP platforms will need this to set ethernet
MAC addresses from board EEPROM.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Non OMAP platforms i.e. Keystone will also need to use the board
EEPROM helpers so let's make the macro platform independent.
Current logic for query of revision, board_name, config returns
NULL. Users of these functions do a direct strncmp to compare.
Unfortunately, as per conventions require two valid strings to compare
against and the current implementation causes a crash when compared
with NULL.
We'd still like to maintain the simplistic usage of these APIs instead
of redundant if (string) res=strncmp(fn(),"cmp",n); flowing all over
the place.
Hence, since the version, name and config is already pre-initialized
with empty string, just dont check for invalid header in the first
place and return the empty string to the caller.
Reported-by: Brad Griffis <bgriffis@ti.com>
[trini: Correct was'nt -> wasn't typo]
DRA7 EVM revH and later EVMs have EEPROM populated that can contain board
description information such as name, revision, DDR definition, etc. Adding
support for this EEPROM format.
Acked-by: Nishanth Menon <nm@ti.com>
Several TI EVMs have EEPROM that can contain board description information
such as revision, DDR definition, serial number, etc. In just about all
cases, these EEPROM are on the I2C bus and provides us the opportunity
to centralize the generic operations involved.
The on-board EEPROM on the BeagleBone Black, BeagleBone, AM335x EVM,
AM43x GP EVM, AM57xx-evm, BeagleBoard-X15 share the same format.
However, DRA-7* EVMs, OMAP4SDP use a modified format.
We hence introduce logic which is generic between these platforms
without enforcing any specific format. This allows the boards to use the
relevant format for operations that they might choose.
This module will compile for all TI SoC based boards when
CONFIG_TI_I2C_BOARD_DETECT is enabled to have optimal build times for
platforms that require this support.
It is important to note that this logic is fundamental to the board
configuration process such as DDR configuration which is needed in
SPL, hence cannot be part of the standard u-boot driver model (which
is available later in the process). Hence, to aid efficiency, the
eeprom contents are copied over to SRAM scratchpad memory area at the
first invocation to retrieve data.
To prevent churn with cases such as DRA7, where eeprom format maybe
incompatible, we introduce a generic common format in eeprom which
is made available over accessor functions for usage.
Special handling for BBG1 EEPROM had to be introduced thanks to the
weird eeprom rev contents used.
The follow on patches introduce the use of this library for AM335x,
AM437x, and AM57xx.
Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
