path: root/board/ti/am57xx/mux_data.h
2016-04-18board: ti: am57xx: Add support for am572x idk in SPLSteve Kipisz
The AM572x-IDK board (Industrial Dev Kit) is a board based on TI's AM5728x SOC which has a dual core 1.5GHz A15 processor. This board is a development platform for the Industrial market with: - 2GB of DDR3L - Dual 1Gbps Ethernet - HDMI, - PRU-ICSS - uSD - 16GB eMMC - CAN - RS-485 - PCIe - USB3.0 - Video Input Port - Industrial IO port and expansion connector The link to the data sheet and TRM can be found here: http://www.ti.com/product/AM5728 NOTE: DT support is still pending upstream kernel acceptance but we should be able to get the base system support with this patch. Signed-off-by: Schuyler Patton <spatton@ti.com> Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-21ARM: dra7x/am57x: Remove pin input/output config from WAKEUP pinsCooper Jr., Franklin
The WAKEUP_X pins are always an input no matter the pinmux mode. However, the 18th bit that typical configures a pin as an input is considered reserved for the WAKEUP_X pins. Therefore, for any WAKEUP pin remove any configuration that sets that pin as an input. Since those pins are only inputs remove any output configuration from those pins. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
2015-11-18board: ti: beagle_x15: Rename to indicate support for TI am57xx evmsKipisz, Steven
BeagleBoard X15 (http://beagleboard.org/x15) support in u-boot does actually support two different platform configuration offered by TI. In addition to BeagleBoard X15, it also supports the TMDXEVM5728 (or more commonly known as AM5728-evm). Information about the TI AM57xx EVM can be found here http://www.ti.com/tool/tmdxevm5728 The EVM configuration is 1-1 compatible with BeagleBoard X15 with the additional support for mPCIe, mSATA, LCD, touchscreen, Camera, push button and TI's wlink8 offering. Hence, we rename the beagle_x15 directory to am57xx to support TI EVMs that use the AM57xx processor. By doing this we have common code reuse. This sets the stage to have a common u-boot image solution for multiple TI EVMs such as that already done for am335x and am437x. This sets the stage for upcoming multiple TI EVMs that share the same code base. NOTE: Commit eae7ae185335 ("am437x: Add am57xx_evm_defconfig using CONFIG_DM") introduced DT support for beagle_x15 under am57xx_evm platform name. However, this ignored the potential confusion arising for users as a result. To prevent this, existing beagle_x15_defconfig is renamed as am57xx_evm_nodt_defconfig to denote that this is the "non device tree" configuration for the same platform. We still retain am57xx-beagle-x15.dts at this point, since we just require the common minimum dts. As a result of this change, users should expect changes in build procedures('make am57xx_evm_nodt_defconfig' instead of 'make beagle_x15_defconfig'). Hopefully, this would be a one-time change. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Schuyler Patton <spatton@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
