path: root/board/ti/am335x
2013-06-10am33xx: Board: Make CPSW section of ethernet initialization depend on CPSW ↵Joel A Fernandes
driver Not doing so breaks cases where CPSW is not required such as for USB RNDIS network boot. Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
2013-06-05am33xx/omap: Move save_omap_boot_params to omap-common/boot-common.cTom Rini
We need to call the save_omap_boot_params function on am33xx/ti81xx and other newer TI SoCs, so move the function to boot-common. Only OMAP4+ has the omap_hw_init_context function so add ifdefs to not call it on am33xx/ti81xx. Call save_omap_boot_params from s_init on am33xx/ti81xx boards. Reviewed-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-10am335x: Update timings for the beaglebone againTom Rini
After further testing we can run DDR at 400MHz so update the timings again. Tested-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24am335x_evm: Add better timings for the new BeagleBoard DDR3 partTom Rini
Tested-by: Rao Bodapati <rao@circuitco.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: refactor emif4/ddr to support multiple EMIF instancesMatt Porter
The AM33xx emif4/ddr support closely matches what is need to support TI814x except that TI814x has two EMIF instances. Refactor all the emif4 helper calls and the config_ddr() init function to use an additional instance number argument. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: convert defines from am33xx-specific to generic namesMatt Porter
Eliminate AM33xx specific names to prepare for TI814x support within AM33xx-land. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am335x: Enable DDR PHY dynamic power down bit for DDR3 boardsVaibhav Hiremath
Enable DDR PHY dynamic power down bit, which enables powering down the IO receiver when not performing read. This also helps in reducing overall power consumption in low power states (suspend/standby). Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08am335x_evm: Add am335x_evm_usbspl build targetTom Rini
We add USB (RNDIS gadget) SPL support as a separate target. We need to pull out YMODEM support in order to be a small enough target binary. Signed-off-by: Tom Rini <trini@ti.com>
2013-02-18am335x_evm: enable support for booting via USBIlya Yanok
This adds necessary config options and a new build target, am335x_evm_usbspl, to enable usb booting and fixes board_eth_init() function to take into account that we may have USB ether support in SPL now. This uses the same MAC for both cpsw and USB, in order to match ROM behavior. The usbspl build target does not contain UART SPL, CPSW SPL or extra environment settings, so that we may fit within our binary size constraint. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-02-12am335x_evm: Fix CPSW ethernet on GP EVM and EVM-SKTom Rini
In commit cfd4ff6 we implemented part of advisory 1.0.10 (internal delay for RGMII mode not supported). This in turn however requires that we set the tx clock delay feature in the PHY itself. Signed-off-by: Tom Rini <trini@ti.com>
2013-02-07Add DDR3 support for AM335x-EVM (Version 1.5A)Jeff Lance
AM335x EVM 1.5A uses Micron MT41J512M8RH-125 SDRAM 4Gb (512Mx8) as the DDR3 chip. [Hebbar Gururaja <gururaja.hebbar@ti.com>] - Resolve merge conflict while rebasing. File structure is changed in the mainline. So re-arrange the code accordingly. - Update commit message to reflect the DDR3 part number Signed-off-by: Jeff Lance <j-lance1@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Hebbar Gururaja <gururaja.hebbar@ti.com>
2013-02-07am335x: display msg when reading MAC from efuseLars Poeschel
When ethaddr is not set in environment the MAC address is read from efuse. The message was only printed in debug case, but this message could be of interest for the ordinary user, so printf it. Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-01-08Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
This required manual merging drivers/mtd/nand/Makefile and adding am335x_evm support for CONFIG_SPL_NAND_DRIVERS
2012-12-10am335x: disable internal delay for RGMII modeYegor Yefremov
According to errata the AM335x device does not support internal delay mode, so RGMII1_IDMODE and RGMII2_IDMODE must be set to 1. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2012-12-10am335x_evm: enable NAND supportIlya Yanok
Enable NAND support for AM335X boards. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-12-10am335x_evm: add nand pinmux definitionIlya Yanok
Add NAND pins mux settings for AM335X devices. Enable NAND pins for AM335X EVM board. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-11-20am335x_evm: enable both musb gadget and hostIlya Yanok
Enable musb gadget in Ethernet mode on port 0 and musb host on port1. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-11-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-11-02am335x_evm: Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG supportTom Rini
We add CONFIG_ENV_VARS_UBOOT_CONFIG, CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG and CONFIG_BOARD_LATE_INIT to set the variables and then fdtfile and findfdt to make us of this. It is now possible to do 'run findfdt' to have fdtfile be set to the value of the dtb file to load for the board we are running on. Signed-off-by: Tom Rini <trini@ti.com>
2012-11-02am335x: add initial AM335x IDK board supportMatthias Fuchs
This patch extends the am335x_evm board for the AM335x IDK. The IDK board uses MII for the ethernet phy (same as Beaglebone board) and MMC0 for storage (but without card detect line). The IDK uses UART3 for console. So u-boot must be build with CONFIG_SERIAL4 and CONFIG_CONS_INDEX=4 or for the am335x_evm_uart3 board configuration as introduced by Andrew Bradfords recent patch series "am33xx: Enable UART {1,2,3,4,5}...". When using the IDK with console on UART0, those patches are not required. In this case the board slightly needs to be modified. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2012-10-30am335x: add mux config for DDR3 version of beagleboneKoen Kooi
This fixes the following boothang in SPL: Unknown board, cannot configure pinmux.### ERROR ### Please RESET the board ### Future commits will add pinmuxes for more on-board peripherals. Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
2012-10-25am33xx: Enable UART{1,2,3,4,5} pin-muxAndrew Bradford
If configured to use UART{1,2,3,4,5} such as on the Beaglebone RS232 cape or on the am335x_evm daughterboard, enable the proper pin-muxing. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-10-25am33xx/ddr_defs.h: rename DDR2/DDR3 defines to their actual part numbersPeter Korsgaard
So other parts can be added. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com>
2012-10-25am33xx: support board specific ddr settingsPeter Korsgaard
Move the hardcoded ddr2/ddr3 settings for the ti boards to board code, so other boards can use different types/timings. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com> [trini: Make apply with rtc32k_enable() in the file] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-25am33xx: move generic parts of pinmux handling out from board/ti/am335xPeter Korsgaard
So they are available for other boards. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com>
2012-10-25am33xx: move ti i2c baseboard header handling to board/ti/am335x/Peter Korsgaard
The i2c header is specific to ti(-derived) boards, and not generic for all am335x boards. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com> [trini: Make re-apply with rtc32k_enable() applied] Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am335x evm: Enable support for spi0Tom Rini
2012-09-01am335x evm: Enable MMC1 pinmuxTom Rini
MMC1 is available in profile 2 on the GP EVM and is exposed on the expansion header on beaglebone. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am335x evm: Initial support for AM335x GP EVM ProfilesTom Rini
The AM335x GP EVM can have one of 8 different profiles selected. Each profile has a different set of peripherals and requires different pinmux configurations that conflict with other profiles. i2c1 is an example of a conflicted mux currently. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am33xx: Rework pinmux functionsTom Rini
- Move definition of the EEPROM contents to <asm/arch/sys_proto.h> - Make some defines a little less generic now. - Pinmux must be done by done by SPL now. - Create 3 pinmux functions, uart0, i2c0 and board. - Add pinmux specific to Starter Kit EVM for MMC now. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am33xx: Add support for TI AM335x StarterKit EVMTom Rini
- Board requires gpio0 #7 to be set to power DDR3. - Board uses DDR3, add a way to determine which DDR type to call config_ddr with. - Both of the above require filling in the header structure early, move it into the data section. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am33xx: Remove board/ti/am335x/evm.cTom Rini
The intention has always been (and boards are to support) an i2c EEPROM that will identify what hardware they are, allowing a single binary to support multiple boards. As such, remove the 'evm.c' file as there is nothing EVM centric in it currently, only SoC peripheral configuration. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am335x_evm: CPSW supportChandan Nath
This patch adds board-specific initialization for CPSW on TI AM335X based boards. Tested on BeagleBone. Signed-off-by: Chandan Nath <chandan.nath@ti.com> [Ilya: split board-specific part into separate patch] Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-09-01am335x_evm: read the on-board EEPROMIlya Yanok
Read the on-board EEPROM during startup to detect the version of the board we are running on (as for now only BeagleBone vs EVM detection is supported). Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-09-01am33xx: pin mux defintions for CPSW switchChandan Nath
This patch adds pin mux settings for CPSW switch found on TI AM335X based boards (MII and RGMII modes). Signed-off-by: Chandan Nath <chandan.nath@ti.com> [Ilya: split pinmux into separate patch] Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-09-01omap: am335x_evm: enable i2c1 channelSteve Sakoman
This patch sets up pinmux, enables fclk, and defines CONFIG_I2C_MULTI_BUS Signed-off-by: Steve Sakoman <steve@sakoman.com>
2012-09-01omap: am335x_evm: remove unused definitionsSteve Sakoman
UART_RESET, UART_CLK_RUNNING_MASK, and UART_SMART_IDLE_EN are defined inn evm.c but not used. Also removes unnecessary include of serial.h PHYS_DRAM_1_SIZE is defined in am335x_evm.h but never used. Signed-off-by: Steve Sakoman <steve@sakoman.com>
2012-07-07am33xx: Do not call init_timer twiceTom Rini
We do not need to call init_timer both in SPL and U-Boot itself, just SPL needs to initialize the timer. Signed-off-by: Tom Rini <trini@ti.com>
2012-01-23ARM: AM33XX: Add i2c supportPatil, Rachna
Add i2c driver board hookup for AM335X EVM Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Patil, Rachna <rachna@ti.com>
2012-01-16ARM:AM33XX: Add SPL support for AM335X EVMChandan Nath
This patch is added to support SPL feature on AM335X platform. In this patch, MMC1 is configured as boot device for SPL and support for other devices will be added in the next patch series. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16ARM:AM33XX: Add mmc/sd supportChandan Nath
This patch add supports for mmc/sd driver on AM335X platform. PLL and pinmux configurations for mmc/sd are configured in this patch. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-10-27ARM:AM33XX: Add support for TI AM335X EVMChandan Nath
This patch adds basic support for booting the board. This patch adds support for the UART necessary to get to the u-boot prompt. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
