Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
Not only am335x supports booting from NOR, i.MX6 SoCs also
supports booting from NOR. Make NOR_BOOT a common
option to let different SoCs share it.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Francois Retief <fgretief@spaceteq.co.za>
Use the generic EEPROM detection logic instead of duplicating the AM
eeprom logic.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Steven Kipisz <s-kipisz2@ti.com>
As mentioned in the previous commit, adding default values in each
Kconfig causes problems because it does not co-exist with the
"depends on" syntax. (Please note this is not a bug of Kconfig.)
We should not do so unless we have a special reason. Actually,
for CONFIG_DM*, we have no good reason to do so.
Generally, CONFIG_DM is not a user-configurable option. Once we
convert a driver into Driver Model, the board only works with Driver
Model, i.e. CONFIG_DM must be always enabled for that board.
So, using "select DM" is more suitable rather than allowing users to
modify it. Another good thing is, Kconfig warns unmet dependencies
for "select" syntax, so we easily notice bugs.
Actually, CONFIG_DM and other related options have been added
without consistency: some into arch/*/Kconfig, some into
board/*/Kconfig, and some into configs/*_defconfig.
This commit prefers "select" and cleans up the following issues.
[1] Never use "CONFIG_DM=n" in defconfig files
It is really rare to add "CONFIG_FOO=n" to disable CONFIG options.
It is more common to use "# CONFIG_FOO is not set". But here, we
do not even have to do it.
Less than half of OMAP3 boards have been converted to Driver Model.
Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is
weird. Instead, add "select DM" only to appropriate boards, which
eventually eliminates "CONFIG_DM=n", etc.
[2] Delete redundant CONFIGs
Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again
in configs/sandbox_defconfig.
Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and
defines it also in omap3_beagle_defconfig and devkit8000_defconfig.
This option has a bool type, not hex.
Fix it and enable it if CONFIG_DM is on because Driver Model always
requires malloc memory. Devices are scanned twice, before/after
relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc
memory before relocation. As it is board-independent, handle it
globally.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Robert Baldyga <r.baldyga@samsung.com>
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig
as 0x400. Each defconfig or Kconfig need not repeat the same value.
Now CONFIG_SPL_BUILD is not defined in Kconfig, so
"!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant.
Move this option to Kconfig and update all boards.
Remove driver model CONFIGs from the board config headers and use Kconfig
instead.
Make enabling support for NOR (and describe where it's seen) be done via
Kconfig.
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
The help message in board/ti/am335x/Kconfig says AM335x has
6 UARTs, so the valid number for CONFIG_CONS_INDEX is from 1 to 6.
Cc: Tom Rini <trini@ti.com>
- Drop CONFIG_SERIAL[1-6] and use CONFIG_CONS_INDEX tests instead
- Add choice and help text to board/ti/am335x/Kconfig
- Correct comment about IDK in board/ti/am335x/mux.c
- Remove am335x_evm_uart* defconfig files as they're just variations
on a config option now.
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
