path: root/board/theobroma-systems
2017-07-11rockchip: correct the bank0 ram sizeKever Yang
The bank0 ram size should be the DRAM size minus reserved size, the DRAM size may be 1GB, 2GB, 4GB, we can not hard code it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Added DECLARE_GLOBAL_DATA_PTR for RK3328, RK3368 and RK3399: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: use common sdram functionKever Yang
Replace the sdram_init() in board init and rockchip_sdram_size() in sdram driver for all the Rockchip SoCs which enable CONFIG_RAM. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Make dram_init() in rk3036-board.c conditional on CONFIG_RAM: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: board: puma_rk3399: build FIT image via u-boot.itbPhilipp Tomsich
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: board: puma_rk3399: derive ethaddr from cpuidKlaus Goger
Generate a MAC address based on the cpuid available in the efuse block: Use the first 6 byte of the cpuid's SHA256 hash and set the locally administered bits. Also ensure that the multicast bit is cleared. The MAC address is only generated and set if there is no ethaddr present in the saved environment. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: board: puma_rk3399: add support for serial# and cpuid# via efusesPhilipp Tomsich
With our efuse driver for the RK3399 ready, we can add the board-specific code that consumes the cpuid from the efuse block and postprocesses it into the system serial (using the same CRC32 based derivation as in Linux). We expose the cpuid via two distinct environment variables: serial# - the serial number, as derived in Linux cpuid# - the raw 16 byte CPU id field from the fuse block Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-05-10rockchip: ARM64: puma-rk3399: get DRAM size from DMC initPhilipp Tomsich
With the RK3399 DRAM controller (DMC) driver providing all the infrastructure, retrieve the DRAM size from the DMC init in the board-specific code (instead of hard-coding) for the RK3399-Q7 (Puma). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-15rockchip: ARM64: split RK3399-Q7 board off the RK3399-EVB boardKlaus Goger
The RK3399-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 connector) system-on-module from Theobroma Systems, featuring the Rockchip RK3399. It provides the following feature set: * up to 4GB DDR3 * on-module SPI-NOR flash * on-module eMMC (with 8-bit interace) * SD card (on a baseboad) via edge connector * Gigabit Ethernet w/ on-module Micrel KSZ9031 GbE PHY * HDMI/eDP/MIPI displays * 2x MIPI-CSI * USB - 1x USB 3.0 dual-role (direct connection) - 2x USB 3.0 host + 1x USB 2.0 (on-module USB 3.0 hub) * on-module STM32 Cortex-M0 companion controller, implementing: - low-power RTC functionality (ISL1208 emulation) - fan controller (AMC6821 emulation) - USB<->CAN bridge controller Note that we use a multi-payload FIT image for booting and have Cortex-M0 payload in a separate subimage: we thus rely on the FIT image loader to put it into the SRAM region that ATF expects it in. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Fixed build warning on puma-rk3399: Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
