path: root/board/theobroma-systems
2018-07-21rockchip: rk3399: change boot_target based on u-boot, spl-boot-deviceKlaus Goger
The order distroboot searches for a boot.scr is fixed at compile time. To make BIOS_DISABLE work as expected and boot from mmc1 instead of mmc0 if enabled, we need to change the environment at runtime. Especially as commit: 482cf22333 ("rockchip: rk3399-puma: add boot-on regulator to override BIOS_DISABLE") enables the eMMC in U-Boot even if BIOS_DISABLE is active. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-01-02rockchip: board: lion-rk3368: reduce env-size default to 8KiBPhilipp Tomsich
We want to have the same configuration defaults for the RK3368-uQ7 as for the RK3399-Q7: this change reduces the default env-size to 8KiB to ensure that it does not overlap the boot-payload on SD/MMC configurations. References: commit fe529e6597c0 ("rockchip: rk3399-puma: reduce env size to 8kiB") Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-01-01rockchip: rk3399-puma: reduce env size to 8kiBJakob Unterwurzacher
This commit changes the size of the enviroment (for the RK3399-Q7) to 8kiB for all possible locations of the environment (i.e. even when the environment is saved to SD card). With the default of 32kiB, the environment overwrites the SPL stage which lives at 16kiB. Signed-off-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [Reworked commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18rockchip: move CONFIG_ENV_SIZE and CONFIG_ENV_OFFSET to KconfigKlaus Goger
This commit adds ENV_SIZE and ENV_OFFSET configuration items for ARCH_ROCKCHIP, but keeps these non-visible (i.e. not prompt is given). With these new items present, the configuration from the header files is moved to Kconfig. Keeping these non-visible is necessary to have the possibility to select new default values if CONFIG_IS_IN_* is changed (interactively or with oldconfig). Otherwise it will always be set to a previous value if used with a prompt. As an example if we do a defconfig with CONFIG_IS_IN_MMC and change it to CONFIG_IS_IN_SPI_FLASH via menuconfig, ENV_SIZE and ENV_OFFSET will not be changed to the correct values as defconfig will already have set them to the default values of CONFIG_IS_IN_MMC in .config. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-17rockchip: rk3399-puma: set gpio4cd iodomain to 1.8VJakob Unterwurzacher
The PCIe reset signal is connected to GPIO4_C6 on the Puma module. This pin is supplied by 1.8V, but the default iodomain setting is 3.0V and in this situation the pin is unable to go high. Linux assumes that this signal works in early boot as PCIe is probed before loading the iodomain driver. Make PCIe work in Linux by setting the gpio4cd iodomain to 1.8V. Signed-off-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-08rockchip: rk3399-puma: preserve leading zeros in serial#Jakob Unterwurzacher
Linux preserves leading zeros in /proc/cpuinfo, so we should as well. Otherwise we have the situation that /sys/firmware/devicetree/base/serial-number and /proc/cpuinfo disagree in Linux. Signed-off-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-30rockchip: rk3399-puma: add code to allow forcing a power-on resetPhilipp Tomsich
The reset circuitry in the RK3399 only resets 'almost all logic' when a software reset is performed. To make our software maintenance easier in the future, we want to have the option (controlled by a DTS property) to force all reset causes other than a power-on reset to trigger a power-on reset via a GPIO trigger. This adds the necessary support to the rk3399-puma (i.e. RK3399-Q7) board-support and the documentation for the new property (sysreset-gpio) within the /config-node. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-30rockchip: rk3399-puma: implement usb_hub_reset_devices for puma-rk3399Philipp Tomsich
For some versions of the RK3399-Q7 (at least revisions v1.1 and v1.2 are affected), we need to turn on the power for the port connected to the on-module USB hub only when the device is probed for the first time to ensure that the hub does not enter a low-power mode (that U-Boot's USB stack can't deal with). Note that this is needed for U-Boot only, as Linux eventually manages to attach the hub even when it has entered into its low-power state (when the hub wakes up the next time) after a few seconds. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
2017-11-26rockchip: board: lion-rk3368: update .its filePhilipp Tomsich
For the RK3368-uQ7, we can now update the .its file to mark the Trusted Firmware as out 'firmware' bootable and annotate both ATF and U-Boot with an OS-type. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26rockchip: board: puma-rk3399: update .its file to use new featuresPhilipp Tomsich
This commit updates the .its file for the RK3399-Q7 to use the new features and demonstrates how to use those: * it marks the ATF as the 'firmware' * it tracks the OS-type for U-Boot and ATF * it loads the PMU (M0) firmware to DRAM and records the location to /fit-images (where our ATF reads it from) With the handoff of the next-stage FDT to ATF in place, we can now use this to pass information about the load addresses and names of each loadables to ATF: now we can load the M0 firmware into DRAM and avoid overwriting parts of the SPL stage. This is achieved by changing our .its-file to use an available area of DRAM as the load-address. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-01rockchip: rk3399-puma: add boot-on regulator to override BIOS_DISABLEPhilipp Tomsich
The (Qseven) BIOS_DISABLE signal on the RK3399-Q7 (Puma) keeps the eMMC and SPI in reset initially and we need to write a GPIO to turn them on before continuing the boot-up. This adds the DTS entries for the additional regulator and makes pinctrl and gpio3 available during SPL. It also adds a hook to the spl_board_init() to ensure that the regulator gets probed and enabled. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-01rockchip: puma-rk3399: update board_init()Philipp Tomsich
The original initialisation code for board_init() was largely lifted from the code on the EVB. However, the RK3399-Q7 can do with a much more concise init sequence. This cleans up the board_init() by updating it to the essentials for the RK3399-Q7 and getting rid of the accumulated cruft. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-01rockchip: rk3399: make spl_board_init board-specificPhilipp Tomsich
The later-stage spl_board_init (as opposed to board_init_f) should set up board-specific details: these differ between the EVB-RK3399 and the RK3399-Q7 (Puma). This moves spl_board_init back into the individual boards and removes the unneeded functionality from Puma. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-01rockchip: board: lion-rk3368: avoid ATF overwriting active SPL stagePhilipp Tomsich
The RK3368-uQ7 ATF has been moved back to 0x100000 (1MB from the start of DRAM) to avoid it overwriting the active SPL stage during FIT image loading. This change adapts the .its to match up (again) with our ATF repository for the RK3368-uQ7. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-18rockchip: puma_rk3399: increase serialno_str sizeKlaus Goger
Increase serialno_str to 17 bytes so it can hold the 16 bytes long serial nummer and the terminating null byte added by snprintf. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2017-09-18rockchip: board: puma_rk3399: update README flash instructionsKlaus Goger
Puma supports other boot sources then SD-Card. Update README to include the required steps. * how to package a SPI-NOR SPL * how to flash eMMC with rkdeveloptool Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-18rockchip: board: lion_rk3368: update README flash instructionsKlaus Goger
Add a section to the README on how to flash the on-board eMMC with the rkdeveloptool. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: lion-rk3368: defconfig: enable DM timer for all stagesPhilipp Tomsich
There is no reasonably robust way (this will be needed so early that diagnostics will be limited) to specify the base-address of the secure timer through the DTS for TPL and SPL. In order to allow us a cleaner way to structure our SPL and TPL stage, we now move to a DM timer driver. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: board: puma_rk3399: rename ATF firmwareKlaus Goger
prefix the bl31 firmware needed to build uboot.itb so it can coexist in the build area with ATFs from other boards (i.e. lion_rk3368) Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: board: puma-rk3399: fix warnings in puma_rk3399/fit_spl_atf.itsPhilipp Tomsich
The ITS file generated warnings due to @<num> designations in the naming which cause DTC to complain as follows: Warning (unit_address_vs_reg): Node /images/uboot@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/atf@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/pmu@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /configurations/conf@1 has a unit name, but no reg property This removes the @<num> part from the names, as we only have a single image for each payload aspect (and only a single configuration) anyway. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: board: lion-rk3368: add support for the RK3368-uQ7Philipp Tomsich
The RK3368-uQ7 (codenamed 'Lion') is a micro-Qseven (40mm x 70mm, MXM-230 edge connector compatible with the Qseven specification) form-factor system-on-module based on the octo-core Rockchip RK3368. It is designed, supported and manufactured by Theobroma Systems. It provides the following features: - 8x Cortex-A53 (in 2 clusters of 4 cores each) - (on-module) up to 4GB of DDR3 memory - (on-module) SPI-NOR flash - (on-module) eMMC - Gigabit Ethernet (with an on-module KSZ9031 PHY) - USB - HDMI - MIPI-DSI/single-channel LVDS (muxed on the 'LVDS-A' pin-group) - various 'slow' interfaces (e.g. UART, SPI, I2C, I2S, ...) Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-27rockchip: puma-rk3399: remove duplicate code (merge artifact)Kever Yang
A few lines (defines and declarations) had been duplicated when the puma-rk3399 board was initially merged. This removes the duplicates and changes the style to use local constants instead of pasted literals. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> [fixed up commit-message & converted to use 'const u32':] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: correct the bank0 ram sizeKever Yang
The bank0 ram size should be the DRAM size minus reserved size, the DRAM size may be 1GB, 2GB, 4GB, we can not hard code it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Added DECLARE_GLOBAL_DATA_PTR for RK3328, RK3368 and RK3399: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: use common sdram functionKever Yang
Replace the sdram_init() in board init and rockchip_sdram_size() in sdram driver for all the Rockchip SoCs which enable CONFIG_RAM. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Make dram_init() in rk3036-board.c conditional on CONFIG_RAM: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: board: puma_rk3399: build FIT image via u-boot.itbPhilipp Tomsich
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: board: puma_rk3399: derive ethaddr from cpuidKlaus Goger
Generate a MAC address based on the cpuid available in the efuse block: Use the first 6 byte of the cpuid's SHA256 hash and set the locally administered bits. Also ensure that the multicast bit is cleared. The MAC address is only generated and set if there is no ethaddr present in the saved environment. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: board: puma_rk3399: add support for serial# and cpuid# via efusesPhilipp Tomsich
With our efuse driver for the RK3399 ready, we can add the board-specific code that consumes the cpuid from the efuse block and postprocesses it into the system serial (using the same CRC32 based derivation as in Linux). We expose the cpuid via two distinct environment variables: serial# - the serial number, as derived in Linux cpuid# - the raw 16 byte CPU id field from the fuse block Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-05-10rockchip: ARM64: puma-rk3399: get DRAM size from DMC initPhilipp Tomsich
With the RK3399 DRAM controller (DMC) driver providing all the infrastructure, retrieve the DRAM size from the DMC init in the board-specific code (instead of hard-coding) for the RK3399-Q7 (Puma). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-15rockchip: ARM64: split RK3399-Q7 board off the RK3399-EVB boardKlaus Goger
The RK3399-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 connector) system-on-module from Theobroma Systems, featuring the Rockchip RK3399. It provides the following feature set: * up to 4GB DDR3 * on-module SPI-NOR flash * on-module eMMC (with 8-bit interace) * SD card (on a baseboad) via edge connector * Gigabit Ethernet w/ on-module Micrel KSZ9031 GbE PHY * HDMI/eDP/MIPI displays * 2x MIPI-CSI * USB - 1x USB 3.0 dual-role (direct connection) - 2x USB 3.0 host + 1x USB 2.0 (on-module USB 3.0 hub) * on-module STM32 Cortex-M0 companion controller, implementing: - low-power RTC functionality (ISL1208 emulation) - fan controller (AMC6821 emulation) - USB<->CAN bridge controller Note that we use a multi-payload FIT image for booting and have Cortex-M0 payload in a separate subimage: we thus rely on the FIT image loader to put it into the SRAM region that ATF expects it in. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Fixed build warning on puma-rk3399: Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
