path: root/board/thecus
2023-02-13arm: mvebu: Power up 2nd SATA port for Thecus N2350Tony Dinh
Currently, only the 1st SATA port is powered up (by GPIO1 12). Add GPIO1 13 in board initialization to power up the 2nd SATA port. Note that this patch depends on the initial add-support patch: https://patchwork.ozlabs.org/project/uboot/patch/20230201231306.7010-1-mibodhi@gmail.com/ Signed-off-by: Tony Dinh <mibodhi@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2023-02-13arm: mvebu: Add support for Thecus N2350 (Armada 385) boardTony Dinh
Thecus N2350 is a NAS based on Marvell Armada 385 SoC. Specification: - Processor: Marvel MV88F6820 Dual Core at 1GHz - 1 GiB DDR4 RAM - 4MB Macronix mx25l3205d SPI flash - 512MB Hynix H27U4G8F2DTR-BC NAND flash - I2C - 2x USB 3.0 - 1x GBE LAN port (PHY: Marvell 88E1510) - 2x SATA (hot swap slots) - 3x buttons - 10x LEDS - serial console Signed-off-by: Tony Dinh <mibodhi@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
