path: root/board/theadorable
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Drop linux/crc8.hSimon Glass
We have an existing U-Boot header for the one function that this defines. Use that instead of the linux/ one. Move over the nice comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-12arm: mvebu: AXP: Enhance PCIe port capability configurationStefan Roese
This patch enables the PCIe port specific link capabilities configuration for Armada XP. The weak function board_sat_r_get() was used to return a common flag for PCIe Gen1 vs Gen2 capability for all PCIe ports. This is now changed with this patch to return a bit per PCIe port (4 bits in this case, bit 0 for PCIe port 0, etc). The theadorable board uses this new feature to configure PCIe port 0 as Gen1 and all other PCIe ports as Gen2 capable. All other AXP boards using this function are not changed in the configuration and still configure all ports as PCIe Gen2. This patch also removes the parameter "pex_mode" from board_serdes_cfg_get() as this parameter was not used in any of the implementations. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Phil Sutter <phil@nwl.cc>
2019-04-12arm: mvebu: theadorable: Add test for ctrl-c in PCIe PEX switch testStefan Roese
The check for the missing PEX switch can lead to an infinite loop, when the PCIe device is not found. It is helpful to enable the user to break out of this boot-loop, to enable booting to the prompt for test cases. This patch adds a 3 second delay in the error case before rebooting. The user can press Ctrl-C in this time to abort the boot-loop. This patch also calls bootcount_inc() before rebooting in the error case. This is needed to increment the bootcounter, since this function is called earlier than the main bootcounter increment. Otherwise the bootcounter will not be incremented in the error case at all. Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-05video: Armada XP: Move driver to DM_VIDEOStefan Roese
This patch moves the Armada XP video / LCD driver to DM_VIDEO. With this move, the legacy interface board_video_init() is removed from the theadorable board code (only user of this video driver). The support via DT will be added in a separate patch. This patch also enables DM_VIDEO for the theadorable board, as this is needed to not break git bisect'ability. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2018-08-06mvebu: select boot device at SoC levelBaruch Siach
Move the gdsys Controlcenter DC specific build time kwbimage.cfg generation code into the mach-mvebu/ directory to be shared by all 32bit mvebu platforms. Remove board specific kwbimage.cfg files, and use the generated one instead. These files are all identical, with two exceptions. Clearfog and Helios4 use the sdio boot device, whereas all others use spi. Update the defconfigs for the exceptional boards to generate the same kwbimage.cfg as before. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2017-09-26arm: mvebu: Remove theadorable_defconfigStefan Roese
Currently, we support 2 "theadorable" MVEBU build targets. One with a stripped down configuration (theadorable) and one with a full blown configuration (theadorable_debug), including PCI, ethernet etc. When we introduced these configs, the plan was to remove the debug version at some point. But now it seems better to keep the full-blown version and remove the "non-debug" version instead. At a later stage, I will rename the remaining "theadorable_debug" target into a more fitting one. Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23arm: mvebu: theadorable: Add 'pcie' test commandStefan Roese
This board specific command tests for the presence of a specified PCIe device (via vendor-ID and device-ID). If the device is not detected, this will get printed. If the device is detected, the board will get resetted so that an easy loop test can be done. The board will reboot until the PCIe device is not detected. Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23arm: mvebu: theadorable: Add board-specific PEX detection pulse widthStefan Roese
Define a board-specific detection pulse-width array for the SerDes PCIe interfaces. If not defined in the board code, the default of currently 2 is used. Values from 0...3 are possible (2 bits). In this case of the theadorable board, PEX interface 0 needs a value of 0 for the detection pulse width so that the PCIe device (Atheros WLAN PCIe device) is consistantly detected. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Adam Shobash <adams@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Konstantin Porotchkin <kostap@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-09-24arm: mvebu: theadorable: Configure board for PCIe 2.0 capabilityStefan Roese
Use a board-specific board_sat_r_get() function to configure the board for PCIe 2.0 capability (e.g. 5GB/s link speed). Otherwise the default of 2.5GB/s will be established. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Remove Board name output in checkboardStefan Roese
This line is not needed, as the board supports DT based probing. And here the "Model:" is already printed: Model: Marvell Armada XP theadorable Board: theadorable One line for the board name is enough. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Add PEX-switch detection and reset codeStefan Roese
Sometimes the PCIe link for the PEX-switch will not come-up. In this case, the board is not in a usable state. This patch makes sure that in this case a soft-reset is issued. If this soft-reset does not result in the PEX-switch being detected after some soft-reset cycles, an I2C message is sent to the uC to issue a complete power-cycle of the board. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Add USB power toggle and tweak USB PHY registerStefan Roese
This patch adds an USB power toggle for theadorable. Additionally, the USB PHY RX Channel Control 0 Register is changed to fix some issues noticed while accessing some specific USB sticks. Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-24arm: mvebu: theadorable: Add StratixV FPGA programming supportStefan Roese
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-27arm: mvebu: Add support for the Armada XP theadorable boardStefan Roese
This patch adds support for the Armada XP (MV78260) based theadorable board. Its equipped with onboard DDR3, UART, ethernet, I2C, SPI NOR, LCD and SATA (SSD) interfaces / devices. Two defconfigs are added: theadorable_defconfig: The production U-Boot version with a stripped down drivers and feature list. This removes networking, USB and PCI support. theadorable_debug_defconfig: The debugging / testing U-Boot version with full support for all drivers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
