path: root/board/theadorable/theadorable.c
2017-03-23arm: mvebu: theadorable: Add 'pcie' test commandStefan Roese
This board specific command tests for the presence of a specified PCIe device (via vendor-ID and device-ID). If the device is not detected, this will get printed. If the device is detected, the board will get resetted so that an easy loop test can be done. The board will reboot until the PCIe device is not detected. Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23arm: mvebu: theadorable: Add board-specific PEX detection pulse widthStefan Roese
Define a board-specific detection pulse-width array for the SerDes PCIe interfaces. If not defined in the board code, the default of currently 2 is used. Values from 0...3 are possible (2 bits). In this case of the theadorable board, PEX interface 0 needs a value of 0 for the detection pulse width so that the PCIe device (Atheros WLAN PCIe device) is consistantly detected. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Adam Shobash <adams@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Konstantin Porotchkin <kostap@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-09-24arm: mvebu: theadorable: Configure board for PCIe 2.0 capabilityStefan Roese
Use a board-specific board_sat_r_get() function to configure the board for PCIe 2.0 capability (e.g. 5GB/s link speed). Otherwise the default of 2.5GB/s will be established. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Remove Board name output in checkboardStefan Roese
This line is not needed, as the board supports DT based probing. And here the "Model:" is already printed: Model: Marvell Armada XP theadorable Board: theadorable One line for the board name is enough. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Add PEX-switch detection and reset codeStefan Roese
Sometimes the PCIe link for the PEX-switch will not come-up. In this case, the board is not in a usable state. This patch makes sure that in this case a soft-reset is issued. If this soft-reset does not result in the PEX-switch being detected after some soft-reset cycles, an I2C message is sent to the uC to issue a complete power-cycle of the board. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Add USB power toggle and tweak USB PHY registerStefan Roese
This patch adds an USB power toggle for theadorable. Additionally, the USB PHY RX Channel Control 0 Register is changed to fix some issues noticed while accessing some specific USB sticks. Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-24arm: mvebu: theadorable: Add StratixV FPGA programming supportStefan Roese
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-27arm: mvebu: Add support for the Armada XP theadorable boardStefan Roese
This patch adds support for the Armada XP (MV78260) based theadorable board. Its equipped with onboard DDR3, UART, ethernet, I2C, SPI NOR, LCD and SATA (SSD) interfaces / devices. Two defconfigs are added: theadorable_defconfig: The production U-Boot version with a stripped down drivers and feature list. This removes networking, USB and PCI support. theadorable_debug_defconfig: The debugging / testing U-Boot version with full support for all drivers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
