path: root/board/theadorable/fpga.c
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-24arm: mvebu: theadorable: Add StratixV FPGA programming supportStefan Roese
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
