path: root/board/terasic/de1-soc/Makefile
2016-12-06socfpga: add support for Terasic DE1-SoC boardAnatolij Gustschin
Add CycloneV based Terasic DE1-SoC board. The board boots from SD/MMC. Ethernet and USB host is supported. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Marek Vasut <marex@denx.de>
