path: root/board/teejet/mt_ventoux
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: spartan3: Avoid CamelCaseMichal Simek
2013-10-20usb: ehci-hcd: add enum usb_init_type parameter to ehci_hcd_init.Troy Kisky
This paramter will later be used to initialize OTG ports in host or device mode. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-06-10ARM: OMAP2+: Rename asm/arch/clocks.h asm/arch/clock.hLokesh Vutla
To be consistent with other ARM platforms, renaming asm/arch-omap*/clocks.h to asm/arch-omap*/clock.h Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-08omap3: allow dynamic selection of gfx_formatNikita Kiryanov
Currently, omap3_dss_panel_config() sets gfx_format to a value that is hardcoded in the code. This forces anyone who wants to use a different gfx_format to make adjustments after calling omap3_dss_panel_config(). This could be avoided if the value of gfx_format were parameterized as input for omap3_dss_panel_config(). Make gfx_format a field in struct panel_config, and update existing structs to set this field to the value that was originally hard coded. Cc: Wolfgang Denk <wd@denx.de> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10OMAP3: TAM3517: add macros for reading eepromStefano Babic
Added macros to read SOM information from the I2C EEPROM. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-12-10OMAP3: fix panel timing on the mt_ventoux boardStefano Babic
2012-10-25OMAP3: mt_ventoux: power on USB at startupStefano Babic
Updated revision of the board uses GPIOs to activate the USB ports. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-15usb: ehci: rework to take advantage of new lowlevel interfaceLucas Stach
Kill off ehci-core.h It was used to specify some static controller data. To support more than one controller being active at any time we have to carry the controller data ourselfes. Change the ehci interface accordingly. NOTE: OMAP implemented the ehci stuff a bit backwards and should be fixed to do the same thing as other platforms. But the change for now is at least compile clean. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-04OMAP3: mt_ventoux: added video supportStefano Babic
2012-09-04OMAP3: mt_ventoux: disable the buzzer at start-upStefano Babic
2012-09-04OMAP3: mt_ventoux: read MAC address from EEPROMStefano Babic
2012-09-04OMAP3: mt_ventoux: Correct board pinmuxStefano Babic
Fix some issues (some pins were not set as GPIOs) Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-05-15omap3: Introduce weak misc_init_rTom Rini
Introduce a __weak misc_init_r function that just runs dieid_num_r(). Remove misc_init_r from cm_t35, mcx, omap3_logic and mt_ventoux as this was all they did for misc_init_r. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-03-27OMAP3: mt_ventoux: updated timing for FPGAStefano Babic
Fix chipselect timing for FPGA Signed-off-by: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com>
2012-02-12ARM: omap3: Added Teejet mt_ventouxStefano Babic
The mt_ventoux board is a custom board using the Technexion TAM3517 module. The patch fixes also the mtdparts variable in the TAM3517 common configuration file. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Igor Grinberg <grinberg@compulab.co.il> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
