path: root/board/technexion
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-26imx: s/docs\/README.imximage/doc\/README.imximage/gJagan Teki
Fixed typo for doc/README.imximage on respective imximage.cfg files. Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-09-06pico-imx6ul: Directly write to register LDOGCTLFabio Estevam
Register LDOGCTL contains only bit 0 as a valid bit, so there is no need to do a read-modify-write operation. Simplify the code by writing directly to this register. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-19pico-imx6ul: Add PMIC supportVanessa Maegima
Add PMIC support. Tested by command "pmic PFUZE3000 dump". Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12pico-imx6ul: Add USB Host supportVanessa Maegima
Add USB host support. Tested by connecting a USB pen drive: => usb start starting USB... USB0: Port not available. USB1: USB EHCI 1.00 scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12pico-imx6ul: Add a README fileVanessa Maegima
Add a README file to help users to install U-boot binary into the eMMC. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-12pico-imx6ul: Add Ethernet supportDiego Dorta
Pico-imx6ul has a KSZ8081 Ethernet PHY. Add support for it. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-04-19Add initial support for Technexion's PICO-IMX6UL-EMMC boardFabio Estevam
Add support for Technexion's PICO-IMX6UL-EMMC board. For information about this board, please visit: http://www.technexion.com/products/pico/pico-som/pico-imx6-emmc Signed-off-by: Richard Hu <richard.hu@technexion.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-10-25twister: add missing includesJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-12-12arm: omap3: Add HEAD acoustics (HA) board variant omap3_ha to tao3530Stefan Roese
The Head acoustics (HA) baseboard used the Technexion TAO3530 SOM and has only some minor differences to the Technexion Thunder baseboard. This patch adds support for this HA baseboard / TAO3530 as the "omap3_ha" build target. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm: omap3: Add board revision output to tao3530Stefan Roese
2013-12-12arm: omap3: Remove bootargs mem_size handlingStefan Roese
The memory size is autodetected and is passed to the Linux kernel either via ATAGs or device-tree (dtb). So there is no need to pass it via the bootargs. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm: omap3: Add SPL support to tao3530Stefan Roese
Add SPL support for the Technexion TAO3530 SOM to replace x-loader. Tested with the Thunder baseboard. Currently this is only tested with the TAO3530 SOM revision (Ax/Bx). Tested by booting via MMC and NAND. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm, omap3: Add support for TechNexion modulesTapani Utriainen
Add support for TechNexion TAO3530 SoM This patch has been posted quite a long time ago. I ported it to the latest mainline U-Boot version. With some additional cleanup and enhancements. Signed-off-by: Tapani Utriainen <tapani@technexion.com> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-10-20usb: ehci-hcd: add enum usb_init_type parameter to ehci_hcd_init.Troy Kisky
This paramter will later be used to initialize OTG ports in host or device mode. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-01OMAP3: drop CONFIG_SPL_OS_BOOT_KEY and use local defineStefano Babic
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2012-12-10OMAP3: TAM3517: add macros for reading eepromStefano Babic
Added macros to read SOM information from the I2C EEPROM. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-15usb: ehci: rework to take advantage of new lowlevel interfaceLucas Stach
Kill off ehci-core.h It was used to specify some static controller data. To support more than one controller being active at any time we have to carry the controller data ourselfes. Change the ehci interface accordingly. NOTE: OMAP implemented the ehci stuff a bit backwards and should be fixed to do the same thing as other platforms. But the change for now is at least compile clean. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-04OMAP3: twister : get MAC address from EEPROMStefano Babic
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-03-27OMAP3: twister: add support to boot Linux from SPLStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Simon Schwarz <simonschwarzcor@gmail.com>
2012-02-12OMAP3: TAM3517: update ehci interfaceStefano Babic
Changed the EHCI interface using the ulpi framework. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-12-24ARM: omap3: add support to Technexion twister boardStefano Babic
The twister board is a development board using the TAM3517 SOM. Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tapani Utrianen <tapani@technexion.com> CC: Tom Rini <tom.rini@gmail.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
