path: root/board/technexion
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-12-12arm: omap3: Add HEAD acoustics (HA) board variant omap3_ha to tao3530Stefan Roese
The Head acoustics (HA) baseboard used the Technexion TAO3530 SOM and has only some minor differences to the Technexion Thunder baseboard. This patch adds support for this HA baseboard / TAO3530 as the "omap3_ha" build target. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm: omap3: Add board revision output to tao3530Stefan Roese
2013-12-12arm: omap3: Remove bootargs mem_size handlingStefan Roese
The memory size is autodetected and is passed to the Linux kernel either via ATAGs or device-tree (dtb). So there is no need to pass it via the bootargs. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm: omap3: Add SPL support to tao3530Stefan Roese
Add SPL support for the Technexion TAO3530 SOM to replace x-loader. Tested with the Thunder baseboard. Currently this is only tested with the TAO3530 SOM revision (Ax/Bx). Tested by booting via MMC and NAND. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm, omap3: Add support for TechNexion modulesTapani Utriainen
Add support for TechNexion TAO3530 SoM This patch has been posted quite a long time ago. I ported it to the latest mainline U-Boot version. With some additional cleanup and enhancements. Signed-off-by: Tapani Utriainen <tapani@technexion.com> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-10-20usb: ehci-hcd: add enum usb_init_type parameter to ehci_hcd_init.Troy Kisky
This paramter will later be used to initialize OTG ports in host or device mode. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-01OMAP3: drop CONFIG_SPL_OS_BOOT_KEY and use local defineStefano Babic
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2012-12-10OMAP3: TAM3517: add macros for reading eepromStefano Babic
Added macros to read SOM information from the I2C EEPROM. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-15usb: ehci: rework to take advantage of new lowlevel interfaceLucas Stach
Kill off ehci-core.h It was used to specify some static controller data. To support more than one controller being active at any time we have to carry the controller data ourselfes. Change the ehci interface accordingly. NOTE: OMAP implemented the ehci stuff a bit backwards and should be fixed to do the same thing as other platforms. But the change for now is at least compile clean. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-04OMAP3: twister : get MAC address from EEPROMStefano Babic
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-03-27OMAP3: twister: add support to boot Linux from SPLStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Simon Schwarz <simonschwarzcor@gmail.com>
2012-02-12OMAP3: TAM3517: update ehci interfaceStefano Babic
Changed the EHCI interface using the ulpi framework. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-12-24ARM: omap3: add support to Technexion twister boardStefano Babic
The twister board is a development board using the TAM3517 SOM. Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tapani Utrianen <tapani@technexion.com> CC: Tom Rini <tom.rini@gmail.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
