Update the README file to take into accound the switch to SPL.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Update the MAINTAINERS file to list Otavio Salvador as the maintainer
for this board.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Our default config already has the secure mode supported, so the
manual step is not required anymore.
The DFU allows a more user friendly use as the details where the
bootloader is installed are abstracted.
The addrmap5 value is the same for the 512MB and 1GB variants,
so there is no need to override it.
Falcon mode boots the kernel directly from SPL, without loading
the full U-Boot.
As pico-imx7d does not have a GPIO for selecting Falcon versus
normal mode, enter in Falcon mode when the customer selects
the CONFIG_SPL_OS_BOOT option in menuconfig.
Convert pico-imx7d to SPL support.
There are two variants of pico-imx7d SOMs:
- One with 512MB of RAM
- One with 1GB of RAM
The 512MB module contains two Hynix H5TC2G63GFR-PBA.
The 1GB module contains two Hynix H5TC4G63GFR-PBA.
The RAM size is determined in runtime by reading GPIO1_12.
While at it, also add USB Serial Download mode support as it
is very helpful for loading SPL and u-boot.img via imx_usb_loader.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
The NXP 4.1 kernel needs to boot with secure boot.
Add information on how to enable secure boot mode.
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Update these macros to use all upper-case to avoid checkpatch
warnings:
ENET_25MHz,
ENET_50MHz,
ENET_125MHz,
Signed-off-by: Eric Nelson <eric@nelint.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Wig Cheng's email bounces, so remove it from the maintainers list.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Add the initial support for pico-imx7d board based on Wig Cheng's
source code.
Add support for eMMC, USB gadget, I2C, PMIC and Ethernet.
For more information about this board, please visit:
http://www.technexion.org/products/pico/pico-som/pico-imx7-emmc
