path: root/board/tcl
2018-03-05spl: Kconfig: Rename SPL_USBETH_SUPPORT to SPL_USB_ETHER to match with the ↵Faiz Abbas
U-boot CONFIG Rename CONFIG_SPL_USBETH_SUPPORT to CONFIG_SPL_USB_ETHER. This enables users to block text using CONFIG_IS_ENABLED() instead of resorting to #if ladders with SPL and non-SPL cases. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop env_relocate_spec() in favour of env_load()Simon Glass
This is a strange name for a function that loads the environment. There is now only one implementation of this function, so use the new env_load() function directly instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-07ARM: am335x: select DM_GPIOMasahiro Yamada
We are supposed to not add config entries with only "default y" in board/SoC Kconfig files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2015-09-11board: Add Toby-Churchill SL50 board support.Enric Balletbò i Serra
Add support for Lightwriter SL50 series board, a small, robust and portable Voice Output Communication Aids (VOCA) designed to meet the particular and changing needs of people with speech loss resulting from a wide range of acquired, progressive and congenital conditions. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
