path: root/board/taskit/stamp9g20
2012-09-04Fixes the crippled console output on PortuxG20.Markus Hubig
In order to use the serial interface on the PortuxG20 we need to enable the level converter first by setting the PC9 pin to high. The level converter needs some time to settle so we have to use the mdelay() function to wait for some time. Unfortunately we have no timers available at board_early_init_f() so we enable the serial output early within board_postclk_init(). Now the U-Boot output looks fine: | U-Boot 2012.07-00132-gaf1a3b0-dirty (Aug 16 2012 - 18:21:32) | | CPU: AT91SAM9G20 | Crystal frequency: 18.432 MHz | CPU clock : 396.288 MHz | Master clock : 132.096 MHz | DRAM: 64 MiB | WARNING: Caches not enabled | NAND: 128 MiB | In: serial | Out: serial | Err: serial | Net: macb0 | Hit any key to stop autoboot: 0 Signed-off-by: Markus Hubig <mhubig@imko.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01at91: Add support for taskit AT91SAM9G20 boards.Markus Hubig
This adds support for the AT91SAM9G20 boards by taskit GmbH. Both boards, Stamp9G20 and PortuxG20, are integrated in one file. PortuxG20 is basically a SBC built around the Stamp9G20. Signed-off-by: Markus Hubig <mhubig@imko.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.deve@googlemail.com>
