path: root/board/syteco
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-05-05imx: zmx25: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior, even if some pad control values could probably be simplified. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-26mx25: Place common functions into sys_proto.hFabio Estevam
imx-regs.h is meant to contain SoC register definitions. Common SoC funtions should go to sys_proto.h instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01MX: Set a common gpio.h for all i.MXStefano Babic
Each i.MX has its own gpio.h, defining the same structure. The internal GPIO controller has the same layout (at least for the register used by u-boot) and can be shared. Signed-off-by: Stefano Babic <sbabic@denx.de> Tested-by: Matt Sealey <matt@genesi-usa.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-11MX25: zmx25: GCC4.6 fix build warningsStefano Babic
Fix: zmx25.c: In function 'board_late_init': zmx25.c:131:25: warning: variable 'padctl' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-11-05arm: jadecpu: Readd MACH_TYPE_JADECPUMatthias Weisser
MACH_TYPE_JADECPU was removed from mach-types.h. Add it to board config file. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-09-30zmx25: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Cc: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30zmx25: Remove dram_init_banksize()Fabio Estevam
As only one RAM bank is used we can rely on the code from arch/arm/lib/board.c Cc: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-04MX25: zmx25: make use of GPIO frameworkStefano Babic
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-14imx: Add support for zmx25 boardMatthias Weisser
zmx25 is a board based on imx25 SoC, 64 Megs of LPDDR, 32 Megs of NOR flash, an optional NAND flash. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-04arm: Update jadecpu boardMatthias Weisser
Enable dcache and arch memset/memcpy for speed reasons Remove of config.mk and some environment overwrites Some generic cleanup Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-09-21arm: Make jadecpu board use relocationMatthias Weisser
This patch modifies jadecpu board so that it is usable with the relocation patches by Heiko Schocher Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
