path: root/board/syteco
2011-07-04arm: Update jadecpu boardMatthias Weisser
Enable dcache and arch memset/memcpy for speed reasons Remove of config.mk and some environment overwrites Some generic cleanup Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-09-21arm: Make jadecpu board use relocationMatthias Weisser
This patch modifies jadecpu board so that it is usable with the relocation patches by Heiko Schocher Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
