path: root/board/sysam
2016-10-31Fix spelling of "occur".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Angelo Dureghello <angelo@sysam.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-25board: amcore: update to use dm serial driverAngelo Dureghello
Update amcore board to use dm serial driver. Signed-off-by: Angelo Dureghello <angelo@sysam.it> --- Changes for v2: - None
2015-04-23m68k: add architecture-specific u-boot.ldsangelo@sysam.it
Add architecture-specific u-boot.lds and remove all board-specific u-boot.lds. All the .text customization that was board-specific have been moved inside the related include/configs, inside a LDS_BOARD_TEXT define. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-05m68k: add amcore board supportangelo@sysam.it
Add Sysam Amcore m68k-based board support. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
