Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
It's a very rare if at all existing occasion when ARC CPU template
is used as is w/o any changes - in the end it's a beauty and competitive
advantage of ARC cores to be tailored for a particular use-case - and
so it doesn't make a lot of sense to offer template-based "-mcpu" selection.
Given for each and every platform we end-up adding quite a few more flags
it's logical to move "-mcpu" selection to platform's definition as well
which we exactly do here.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
These functions belong in cpu_func.h so move them over.
On AXS10x boards we have non-standard NAND controller
which was never really used a lot as there're other much more
convenient [as they are standard & removable] persistent media
like SD-card and USB mass storage.
Moreover after recent changes we face with some NAND controller
runtime issues. So instead of keeping support of yet another
non-standard peripheral we're dropping its support for good.
This allows us to print nice board name on boot.
So now we may detect MMC/SD-card existence and
instead of completely misleading message on missing card:
------------------------>8-----------------------
Loading Environment from FAT... Card did not respond to voltage select!
we now get very clear one:
Loading Environment from FAT... MMC: no card present
Since U-Boot tools are being built anyways it's much nicer
to use them instead of relying on some of them bein installed
on build host (which might easily not be the case).
AXS10x boards have preloader that reads SPI flash pages and searches
special image header to fetch and load binary.
Add tool, make target (bsp-generate) to generate
update script and u-boot binary image with header for preloader.
Also add script to default environment to apply updates.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Refactor GO and PREP subcommands implementation for a simpler
override in the boards platform code.
In axs103 v1.1 procedure to kick-start slave cores has changed quite a bit
compared t previous implementation.
In particular:
* We used to have a generic START bit for all cores selected by CORE_SEL
mask. But now we don't touch CORE_SEL at all because we have a dedicated
START bit for each core:
bit 0: Core 0 (master)
bit 1: Core 1 (slave)
* Now there's no need to select "manual" mode of core start
Additional challenge for us is how to tell which axs103 firmware we're
dealing with. For now we'll rely on ARC core version which was bumped
from 2.1c to 3.0.
* Rely on default pulse polarity value
* Don't mess with "multicore" value as it doesn't affect execution
In essence we now do a bare minimal stuff:
1) Select HS38x2_1 with CORE_SEL=1 bits
2) Select "manual" core start (via CREG) with START_MODE=0
3) Generate cpu_start pulse with START=1
We want to use the same device tree blobs in both Linux and U-Boot for
ARC boards.
Earlier device tree sources in U-Boot were very simplified and hadn't been
updated for quite a long period of time.
So this commit is the first step on the road to unified device tree blobs.
First of all we re-organize device tree sources for AXS10X boards.
As AXS101 and AXS103 boards consist of AXS10X motherboard and AXC001 and
AXC003 cpu tiles respectively we add corresponding device tree source
files: axs10x_mb.dtsi for motherboard, axc001.dtsi and axc003.dtsi for
cpu tiles and axs101.dts and axs103.dts to represent actual boards.
Also we delete axs10x.dts as it is no longer used.
One more important change - we add timer device to ARC skeleton device
tree sources as both ARC700 and ARCHS cores contain such timer.
We add core_clk nodes to abilis_tb100, nsim, axc001 and axc003 device tree
sources as it is referenced via phandle from timer node in common
skeleton.dtsi file.
Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com>
As of now we have 2 flavors of ARC SDP boards:
1) AXS101 - with ARC770 in ASIC
2) AXS103 - with ARC HS38 in FPGA
Both options share exactly the same base-board and only differ with
CPU-tiles in use. That means all peripherals are the same (they are
implemented in FPGA on the base-board) and so generic board could be
used for both.
While at it:
* Recreated defconfigs with savedefconfig
* In include/configs/axs10x.h numerical sizes replaced with
defines from linux/sizes.h for better readability.
