path: root/board/sx1
2004-10-10* Configure SX1 board to use drivers/cfi_flash.cwdenk
* Patches by Michael Bendzick, 30 Aug 2004: - Configure omap1510inn board to use drivers/cfi_flash.c - Make drivers/cfi_flash.c protect environment and redundant environment. * Patch by Steven Scholz, 23 Jun 2004: - Add script (tools/img2brec.sh) to programm U-Boot into (Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
2004-03-12SX1 patches: use "serial#" for USB serial #;wdenk
use redundand environment storage; auto-set console on USB port (using preboot command)
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
