path: root/board/sunxi
2014-10-08sunxi: Fix gmac not working reliable on the BananapiHans de Goede
In order for the gmac nic to work reliable on the Bananapi, we need to set bits 10-12 GTXDC "GMAC Transmit Clock Delay Chain" of the GMAC clk register (0x01c20164) to 3. Without this about 9 out of 10 ethernet packets get lost, with this setting there is no packet loss. So far setting these bits is only necessary on the Bananapi, so this commit solves this with a bit of #ifdef CONFIG_BANANAPI code. If in the future we need to do something similar for other boards, we can create a specific CONFIG_FOO option for this then. Reported-by: Karsten Merker <merker@debian.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Karsten Merker <merker@debian.org> Tested-by: Zoltan HERPAI <wigyori@openwrt.org> Tested-by: Tony Zhang <tony.zhang@lemaker.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-09-05sun7i: Add support for Olimex A20-OLinuXino-LIMEFUKAUMI Naoki
This patch adds support for Olimex A20-OLinuXino-LIME board. Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-09-05sunxi: Correct typo CONFIG_FTDFILE => CONFIG_FDTFILEIan Campbell
Patch is the result of: sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig Reported-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> [ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
2014-08-12sunxi: Add environment settings to make extlinux.conf booting workHans de Goede
Automatic booting using an extlinux.conf file requires various environment variables to be set. Also modify CONFIG_SYS_LOAD_ADDR and CONFIG_STANDALONE_LOAD_ADDR to match the value chosen for kernel_addr_r, see the added comment for why the new value is chosen. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-08-12sunxi: Kconfig: move common settings into a shared code blockHans de Goede
SYS_CPU, SYS_BOARD and SYS_SOC are identical for all sunxi boards, move them to a shared code block. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31sun7i: Add bananapi boardHans de Goede
The Banana Pi is an A20 based development board using Raspberry Pi compatible IO headers. It comes with 1 GB RAM, 1 Gb ethernet, 2x USB host, sata, hdmi and stereo audio out + various expansion headers: http://www.lemaker.org/ Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31sun7i: Add support for a number of new sun7i boardsHans de Goede
Add support for boards which I own and which already have a dts file in the upstream kernel. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31sun5i: Add support for a number of new sun5i boardsHans de Goede
2014-07-31sun4i: Add support for a number of new sun4i boardsHans de Goede
2014-07-31ahci: provide sunxi SATA driver using AHCI platform frameworkIan Campbell
This enables the necessary clocks, in AHB0 and in PLL6_CFG. This is done for sun7i only since I don't have access to any other sunxi platforms with sata included. The PHY setup is derived from the Alwinner releases and Linux, but is mostly undocumented. The Allwinner AHCI controller also requires some magic (and, again, undocumented) DMA initialisation when starting a port. This is added under a suitable ifdef. This option is enabled for Cubieboard, Cubieboard2 and Cubietruck based on contents of Linux DTS files, including SATA power pin config taken from the DTS. All build tested, but runtime tested on Cubieboard2 and Cubietruck only. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-07-18sunxi: add Cubieboard2 supportIan Campbell
This is a sun7i (A20) based followup to the sun4i (A10) Cubieboard. It has GMAC using MII mode. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com>
2014-07-18sunxi: use random parts of SID to set ethaddrJonathan Liu
Similar to the USB NIC found on OMAP5uEVM, PandaBoard and BeagleBoard-XM boards, the sunxi SoCs have a NIC onboard without an embedded MAC address. Just like the omap used on these boards, the sunxi SoCs do have a unique chip id, in the form of the 128 bit SID register: http://linux-sunxi.org/SID_Register_Guide So mimick the BeagleBoard-XM board code (commit 548a64d8) and use the chip id to generate a unique fixed MAC address. We check for the SID not being all 0, since some early A20 batches shipped without having there SID programmed. Note we use specific parts of the 128 bits, since some parts indicate the SoC family / revision, and thus are fixed. The algorithm for this was taken from the linux-sunxi.org kernels. Signed-off-by: Jonathan Liu <net147@gmail.com> [hdegoede@redhat.com: Expanded the commit message with some more info] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-18sunxi: Add axp152 pmic supportHans de Goede
Add support for the x-powers axp152 pmic which is found on most A10s boards and enable it for the r7-tv-dongle board. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-18sunxi: Add axp209 pmic supportHenrik Nordstrom
Add support for the x-powers axp209 pmic which is found on most A10, A13 and A20 boards. And enable AXP209 support for the Cubietruck and Cubieboard boards. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-18sunxi: Add i2c supportHans de Goede
Add support for the i2c controller found on all Allwinner sunxi SoCs, this is the same controller as found on the Marvell orion5x and kirkwood SoC families, with a slightly different register layout, so this patch uses the existing mvtwsi code. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-By: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Heiko Schocher <hs@denx.de> [ ijc -- updated u-boot-spl-fel.lds ]
2014-07-06sunxi: Add support for using MII phy-s with the GMAC nicChen-Yu Tsai
Many A20 boards (ie Cubieboard2, A20-OLinuXino_MICRO) use an 100 Mbit MII phy together with the GMAC nic found in the A20 SoC, add support for this (this will get used when we add these boards in a later patch). Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-06sunxi: Add sun5i supportHans de Goede
Add support for the Allwinner A13 and A10s SoCs also know as the Allwinner sun5i family, and the A13-OLinuXinoM A13 based and r7-tv-dongle A10s based boards. The only differences compared to the already supported sun4i and sun7i families are all in the DRAM controller initialization: -Different hcpr values -Different MBUS settings -Some other small initialization changes Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-06sunxi: Add sun4i supportHans de Goede
Add support for the Allwinner A10 SoC also known as the Allwinner sun4i family, and add the Cubieboard board which uses the A10 SoC. Compared to sun7 only the DRAM controller is a bit different: -Controller reset bits are inverted, but only for Rev. A -Different hpcr values -No MBUS on sun4i -Various other initialization changes Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-05-25sunxi: mmc supportIan Campbell
On Mon, 2014-05-05 at 14:18 +0200, Stefan Roese wrote: > > + case 1: > > +#if CONFIG_MMC1_PG > Are you sure that this is correct and shouldn't be: > > +#ifdef CONFIG_MMC1_PG > > ? It's "correct" in so far as it works (the boards.cfg config stuff #defines things to 1), but I think you are right that it isn't the preferred style. But... > A quick scan through this patch series shows that this define > is not set at all. Perhaps its outdated? Or is it used to support > some other sunxi SoC? Not sure, perhaps it should be removed for > now. ...I had thought that it was to support some other board which wasn't being upstreamed right now, so eventually useful and harmless for now, but I've just checked and it isn't actually used by any of the boards in u-boot-sunxi.git. So rather than fix it to use #ifdef lets drop it. Rather than resend the entire series, here is v5.1 of this patch. > Other than this please add my: > > Reviewed-by: Stefan Roese <sr@denx.de> Thanks! 8<--------------------------------- >From 20704e35a41664de5f516ed0e02981ac06085102 Mon Sep 17 00:00:00 2001 From: Ian Campbell <ijc@hellion.org.uk> Date: Fri, 7 Mar 2014 04:29:39 +0000 Subject: [PATCH v5.1 7/8] sunxi: mmc support This adds support for the MMC controller on the Allwinner A20 (sun7i) processor. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Luke Leighton <lkcl@lkcl.net> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Wills Wang <wills.wang.open@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Cc: Aaron Maoye <leafy.myeh@allwinnertech.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-05-25sunxi: add gmac Ethernet supportIan Campbell
Add support for the GMAC Ethernet controller on Allwinner A20 (sun7i) processors. Enable for the Cubietruck. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-05-25sunxi: add support for Cubietruck booting in FEL modeIan Campbell
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Tom Rini <trini@ti.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-05-25sunxi: add sun7i cpu, board and start of day supportIan Campbell
This patch adds generic board, start of day and basic build system support for the Allwinner A20 (sun7i) processor. This code will not been compiled until the build is hooked up in a later patch. It has been split out to keep the patches manageable. Signed-off-by: Adam Sampson <ats@offog.org> Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Emilio López <emilio@elopez.com.ar> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Luc Verhaegen <libv@skynet.be> Signed-off-by: Luke Leighton <lkcl@lkcl.net> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Patrick Wood <patrickhwood@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wills Wang <wills.wang.open@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Reviewed-by: Tom Rini <trini@ti.com>
