path: root/board/sunxi
2017-06-14sun50i: h5: Add initial NanoPi NEO2 supportJagan Teki
NanoPi NEO2 is designed and developed by FriendlyElec using the Allwinner 64-bit H5 SOC. NanoPi Neo2 key features - Allwinner H5, Quad-core 64-bit Cortex-A53 - 512MB DDR3 RAM - microSD slot - 10/100/1000M Ethernet - Serial Debug Port - 5V 2A DC MicroUSB power-supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-14sun50i: a64: Add initial Orangepi Win/WinPlus supportJagan Teki
Orangepi Win/WinPlus is an open-source single-board computer using the Allwinner A64 SOC. A64 Orangepi Win/WinPlus has - A64 Quad-core Cortex-A53 64bit - 1GB(Win)/2GB(Win Plus) DDR3 SDRAM - Debug TTL UART - Four USB 2.0 - HDMI - LCD - Audio and MIC - Wifi + BT - IR receiver - 5V DC power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-14sun50i: h5: Add initial Orangepi Zero Plus 2 supportJagan Teki
Orangepi Zero Plus 2 is an open-source single-board computer using the Allwinner h5 SOC. H5 Orangepi Zero Plus 2 has - Quad-core Cortex-A53 - 512MB DDR3 - micrSD slot and 8GB eMMC - Debug TTL UART - HDMI - Wifi + BT - OTG+power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: add a defconfig for SoPine w/ official baseboardIcenowy Zheng
The SoPine is a SoM by Pine64, with an Allwinner A64 SoC, a LPDDR3 DRAM chip, an AXP803 PMIC, a SPI NOR Flash and a MicroSD slot. The card detect pin of the MicroSD slot is broken, however, it doesn't matter as the design of SoPine didn't allow hot-swapping the MicroSD card (The MicroSD slot is at the back of the SoM, and when the SoM is installed on the baseboard, it's nearly impossible to remove the MicroSD). The official baseboard of it is a board with nearly the same connectors with the original Pine64+, with the MicroUSB power jack replaced, and at the position of MicroSD slot a eMMC module slot is added. Add support for SoPine with the official baseboard by adding its defconfig file. It still uses the device tree of Pine64, however, it will change after a proper device tree of SoPine with baseboard is accepted by Linux mainline. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> [Update board/sunxi/MAINTAINERS] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sun8i: h3: Add initial NanoPi M1 Plus supportJagan Teki
NanoPi M1 Plus is designed and developed by FriendlyElec for professionals, enterprise users, makers and hobbyists using the Allwinner H3 SOC. NanoPi M1 Plus key features - Allwinner H3, Quad-core Cortex-A7@1.2GHz - 1GB DDR3 RAM - 8GB eMMC - microSD slot - 10/100/1000M Ethernet - Serial Debug Port - 5V 2A DC power-supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-05arm: Include asm/setup.h explictlySimon Glass
Include this header where needed so we do not need to rely on common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-02sun50i: h5: Add initial Orangepi Prime supportJagan Teki
Orangepi Prime is an open-source single-board computer using the Allwinner h5 SOC. H5 Orangepi Prime has - Quad-core Cortex-A53 - 2GB DDR3 - Debug TTL UART - 1000M/100M Ethernet RJ45 - Three USB 2.0 - HDMI - Audio and MIC - Wifi + BT - IR receiver - HDMI - Wifi + BT Boot from MMC: ------------- U-Boot SPL 2017.05-00662-ga3f4c05-dirty (May 25 2017 - 13:30:14) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000) NOTICE: Configuring SPC Controller NOTICE: BL3-1: v1.0(debug):aa75c8d NOTICE: BL3-1: Built : 18:28:27, May 24 2017 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9 U-Boot 2017.05-00662-ga3f4c05-dirty (May 25 2017 - 13:30:14 +0000) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: OrangePi Prime DRAM: 2 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface7 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-06-01sun50i: a64: Add initial Banana Pi M64 supportJagan Teki
BPI-M64 is a 64-bit quad-core mini single board computer using the Allwinner A64 SOC. BPI-M64 features - 1.2 Ghz Quad-Core ARM Cortex A53 - 2GB DDR3 SDRAM with 733MHz - MicroSD/eMMC(8GB) - 10/100/1000Mbps ethernet (Realtek RTL8211E/D) - Wifi + BT - IR receiver - Audio In/Out - Video In/Out - 5V 2A DC power-supply For dts file, Sync with Linux commit 4879b7ae("Merge tag 'dmaengine-4.12-rc1'"). Boot from MMC: ------------- U-Boot SPL 2017.05-00667-g85dd258-dirty (May 29 2017 - 13:07:31) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL3-1: Running on A64/H64 (1689) in SRAM A2 (@0x44000) NOTICE: Configuring SPC Controller NOTICE: BL3-1: v1.0(debug):aa75c8d NOTICE: BL3-1: Built : 18:28:27, May 24 2017 NOTICE: Configuring AXP PMIC NOTICE: PMIC: setup successful INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9 U-Boot 2017.05-00667-g85dd258-dirty (May 29 2017 - 13:07:31 +0000) Allwinner Technology CPU: Allwinner A64 (SUN50I) Model: BananaPi-M64 DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-30sunxi: Add support for NanoPi M1Mylene JOSSERAND
NanoPi M1 is a board based on Allwinner H3 CPU. This commit adds the support for this platform with: - an include device tree which enables UART, LEDs, GPIO key switch, 1 USB host ports and the SD-card as a dtsi file. - a device tree specific to this board that enables the 2 additional USB ports - a defconfig file for minimal support - a section in MAINTAINERS (add myself) Synchronized with the kernel device tree, from commits: sun8i-nanopi.dtsi: 85d2913614d9ab899d23b7ab7d22d23cf45bd1de sun8i-h3-nanopi-m1.dts: 10efbf5f16336b7540ad6a16aa1cb0b26bab033b Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2017-05-22mksunxi_fit_atf.sh: Allow for this to complete when bl31.bin is missingTom Rini
In situations like an autobuilder we are likely to not have bl31.bin present and thus would fail to build and propagate the error upwards. Instead, print a big warning to stderr so that human will see that something is wrong but complete the build. Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-17sunxi: Move maintainership for Pine64Andre Przywara
After speaking to Hans at FOSDEM, he is fine with transferring the maintainership of the Pine64 boards over to me. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-17sunxi: update Pine64 READMEAndre Przywara
With the DRAM init code and the SPL's ability to load the ATF binary as well, we can now officially get rid of the boot0 boot method, which involed a closed-source proprietary blob to be used. Rework the Pine64 README file to document how to build the firmware. Also since these instructions now cover more boards, rename the file to README.sunxi64 to reflect this. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-17sunxi: use SPL header DT name for FIT board matchingAndre Przywara
Now that we can store a DT name in the SPL header, use this string (if available) when finding the right DT blob to load for U-Boot proper. This allows a generic U-Boot (proper) image to be combined with a bunch of supported DTs, with just the SPL (possibly only that string) to be different. Eventually this string can be written after the build process by some firmware update tool. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-17sunxi: 64-bit SoCs: introduce FIT generator scriptAndre Przywara
Now that the Makefile can call a generator script to build a more advanced FIT image, let's use this feature to address the needs of Allwinner boards with 64-bit SoCs (A64 and H5). The (DTB stripped) U-Boot binary and the ATF are static, but we allow an arbitrary number of supported device trees to be passed. The script enters both a DT entry in the /images node and the respective subnode in /configurations to support all listed DTBs. The location of the bl31.bin image from the ARM Trusted Firmware build can either by specified via the BL31 environment variable. If this is not set, the script looks for bl31.bin in U-Boot's build directory (which could be a symlink as well). Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-17sunxi: SPL: add FIT config selector for Pine64 boardsAndre Przywara
For a board or platform to support FIT loading in the SPL, it has to provide a board_fit_config_name_match() routine, which helps to select one of possibly multiple DTBs contained in a FIT image. Provide a simple function which chooses the DT name U-Boot was configured with. If the DT name is one of the two Pine64 versions, determine the exact model by checking the DRAM size. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com>
2017-05-17sunxi: SPL: store RAM size in gdAndre Przywara
The sunxi SPL was holding the detected RAM size in some local variable only, so it wasn't accessible for other functions. Store the value in gd->ram_size instead, so it can be used later on. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-15mmc: replace CONFIG_GENERIC_MMC with CONFIG_MMCMasahiro Yamada
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig. We do not need two options for the same feature. Deprecate the former. This commit was generated with the sed script 's/GENERIC_MMC/MMC/' and manual fixup of drivers/mmc/Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-04sunxi: add support for Banana Pi M2 Plus boardIcenowy Zheng
Banana Pi M2 Plus is an Allwinner H3-based SBC by Sinovoip, which has already mainline device tree file that have landed into U-Boot source tree. Add a defconfig file for it and add the MAINTAINERS items. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Reviewed-by: Jagan Teki <jagan@openedev.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-02ARM: sunxi: move board/sunxi/Kconfig to arch/arm/mach-sunxi/KconfigMasahiro Yamada
For the consistent location of SoC-level Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-28sunxi: video: Add A64/H3/H5 HDMI driverJernej Skrabec
This commit adds support for HDMI output. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-28sunxi: Enable DM_I2C for A64/H3/H5Jernej Skrabec
This commits enable DM I2C support for A64/H3/H5 SoCs. It is not enabled globaly for all sunxi SoCs, because some boards use PMICs which are connected through I2C. In order to keep same functionality, PMIC drivers needs to be ported to DM too. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-28sunxi: i2c: Add support for DM I2CJernej Skrabec
This commit adds support for DM I2C on sunxi platform. It can coexist with old style sunxi I2C driver, because it is still used in SPL and by some SoCs. Because sunxi platform doesn't yet support DM clk, reset and pinctrl driver, workaround is needed to enable clocks and set resets and pinctrls. This is done by calling i2c_init_board() in board_init(). This means that CONFIG_I2Cx_ENABLE options needs to be correctly set in order to use needed I2C controller. Commit is based on the previous patch made by Philipp Tomsich Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-28sunxi: Move function for later convenienceJernej Skrabec
This commit only moves i2c_init_board() function almost to the top and doesn't have any functional changes. This is needed for a temporary workaround in next commit when support for DM I2C will be introduced. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-21sunxi: add support for Lichee Pi ZeroIcenowy Zheng
Lichee Pi Zero is a development board with a V3s SoC, which features 64MiB DRAM co-packaged within the SoC, a TF slot, a SPI NOR slot (not soldered in production batch), a 40-pin RGB LCD connector and some extra pins available as 2.54mm pins or stamp holes. Add support for it. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-21sunxi: add basic V3s supportIcenowy Zheng
Basic U-Boot support is now present for V3s. Some memory addresses are changed specially for V3s, as the original address map cannot fit into a so small DRAM. As the DRAM controller code needs a big refactor, the SPL support is disabled in this version. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add clock support for DE2/HDMI/TCON on newer SoCsJernej Skrabec
This is needed for HDMI, which will be added later. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add support for Bananapi M2 UltraChen-Yu Tsai
The Bananapi M2 Ultra is the first publicly available development board featuring the R40 SoC. This patch add barebone dtsi/dts files for the R40 and Bananapi M2 Ultra, as well as a defconfig for it. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add PSCI support for R40Chen-Yu Tsai
The R40's CPU controls are a combination of sun6i and sun7i. All controls are in the CPUCFG block, and it seems the R40 does not have a PRCM block. The core reset, power gating and clamp controls are grouped like sun6i. Last, the R40 does not have a secure SRAM block. This patch adds a PSCI implementation for CPU bring-up and hotplug for the R40. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Enable SPL for R40Chen-Yu Tsai
Now that we can do DRAM initialization for the R40, we can enable SPL support for it. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Provide defaults for R40 DRAM settingsChen-Yu Tsai
These values were taken from the Banana Pi M2 Ultra fex file found in the released vendor BSP. This is the only publicly available R40 device at the time of this writing. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add mmc[1-3] pinmux settings for R40Chen-Yu Tsai
The PIO is generally compatible with the A20, except that it routes the full 8 bits and eMMC reset pins for mmc2. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Enable AXP221s in I2C mode with the R40 SoCChen-Yu Tsai
The R40 SoC uses the AXP221s in I2C mode to supply power. Some regulator's common usages have changed, and also the recommended voltage for existing usages have changed. Update the defaults to match. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add initial support for R40Chen-Yu Tsai
The R40 is the successor to the A20. It is a hybrid of the A20, A33 and the H3. The R40's PIO controller is compatible with the A20, Reuse the A20 UART and I2C muxing code by adding the R40's macro. The display pipeline is the newer DE 2.0 variant. Block enabling video on R40 for now. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Split up long Kconfig linesChen-Yu Tsai
Currently we have some lines in board/sunxi/Kconfig that are very long. These line either provide default values for a set of SoCs, or limit some option to a subset of sunxi SoCs. Fortunately Kconfig makes it easy to split them. The Kconfig language document states If multiple dependencies are defined, they are connected with '&&'. This means we can split existing dependencies at "&&" symbols. This applies to both the "depends on" lines and "if" expressions. This patch splits them up to one symbol per line. This will make it easier to add, remove, or modify one item at a time. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Convert CONFIG_MACPWR to KconfigMylène Josserand
Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs that used it in SYS_EXTRA_OPTIONS. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Convert CONFIG_SATAPWR to KconfigMylène Josserand
Convert the CONFIG_SATAPWR into kconfig. Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some defconfigs. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-18sunxi: Add maintainer of the NanoPi NEO AirJelle van der Waa
Add myself as maintainer of the NanoPi NEO Air board. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-08Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2017-04-08spl: Kconfig: SPL_MMC_SUPPORT depends on GENERIC_MMCAlexandru Gagniuc
spl_mmc.c calls mmc_initialize(). This symbol is provided in drivers/mmc/mmc.c when CONFIG_GENERIC_MMC is enabled. The sunxi Kconfig case is an oddball because it redefines SPL_MMC_SUPPORT. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> [trini: Update arch/arm/cpu/armv8/zynqmp/Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-07arm: sunxi: Add Sunchip CX-A99 initial supportRask Ingemann Lambertsen
The Sunchip CX-A99 is a board used in some media players. It features: An Allwinner A80 ARM SoC (4 * Cortex-A7 + 4 * Cortex-A15 cores) 2 GiB or 4 GiB DDR3 DRAM AXP808 PMIC 16 GB or 32 GB eMMC SDIO Wifi/Bluetooth/FM module SD card slot 1 USB 3.0 connector 2 USB 2.0 connectors SATA connector UART connector (internally) for serial console Ethernet connector (10/100/1000 Mbit/s) HDMI connector Composite video and analog audio connector S/PDIF connector IR remote control receiver This patch adds a defconfig for the board. The DRAM settings are as found in the vendor sys_config.fex file. It has a preliminary device tree for use until a device tree is accepted upstream, after which it can be replaced by the upstream version. Signed-off-by: Rask Ingemann Lambertsen <rask@formelder.dk> [squash commits, and edited new meanful commit message] Signed-off-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-07scripts: sunxi: Build an raw SPL imageMaxime Ripard
Introduce a new sunxi-spl-with-ecc.bin image with already the right header, ECC, randomizer and padding for the BROM to be able to read it. It needs to be flashed using a raw access to the NAND so that the controller doesn't change a thing to it, since we already have all the right parameters. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-04-05sunxi: Add OrangePi PC 2 initial supportAndre Przywara
The OrangePi PC 2 is a typical SBC with the 64-bit Allwinner H5 SoC. Add a (64-bit only) defconfig defining the required options to build the U-Boot proper. Create a new .dts file for it by including the (32-bit) H3 SoC .dtsi and changing the differing components accordingly. This is a preliminary device tree mostly for U-Boot's own sake, it is expected to be updated once the official DT gets accepted upstream. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [squash the commits, update the commit message] Signed-off-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05sunxi: introduce Allwinner H5 config optionAndre Przywara
The Allwinner H5 Soc is bascially an H3 with high SRAM and ARMv8 cores. As the peripherals and the pinmuxing are almost identical, we piggy back on the shared MACH_SUN8I_H3_H5 config symbol. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05sunxi: prepare for sharing MACH_SUN8I_H3 config symbolAndre Przywara
The Allwinner H5 is very close to the H3 SoC, but has ARMv8 cores. To allow sharing the clocks, GPIO and driver code easily, create an architecture agnostic MACH_SUNXI_H3_H5 Kconfig symbol. Rename the existing symbol to MACH_SUNXI_H3_H5 where code is shared and let it be selected by a new shared Kconfig option. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-05sunxi: Kconfig: introduce CONFIG_SUNXI_HIGH_SRAMAndre Przywara
Traditionally Allwinner SoCs have their boot ROM mapped just below 4GB, while the first SRAM region is mapped at address 0. With the extended physical memory support of the A80 this was changed, so the BROM is now at address 0 and the SRAM region starts right behind this at 64KB. This configuration seems to be called "high SRAM". Instead of enumerating the SoCs which have copied this configuration, let's call a spade a spade and introduce a Kconfig option for this setup. SoCs implementing this (A80, A64 and H5, so far), can then select this configuration. Simplify the config header definition on the way. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05sunxi: simplify ACTLR.SMP bit set #ifdefAndre Przywara
Instead of enumerating all SoC families that need that bit set, let's just express this more clearly: The SMP bits needs to be set on SMP capable ARMv7 CPUs. It's much easier in Kconfig to express it the other way round, so we use ! CPU_IS_UP and ! ARM64. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-05ARM: rename CONFIG_TIMER_CLK_FREQ to COUNTER_FREQUENCYAndre Przywara
Many ARMv8 boards define a constant COUNTER_FREQUENCY to specify the frequency of the ARM Generic Timer (aka. arch timer). ARMv7 boards traditionally used CONFIG_TIMER_CLK_FREQ for the same purpose. It seems useful to unify them. Since there are less occurences of the latter version, lets convert all users over to COUNTER_FREQUENCY. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-15sunxi: add orangepi zero defconfigIcenowy Zheng
Orange Pi Zero is a board designed by Xunlong. It has an Allwinner H2+ SoC (similar to H3, which shares the same SoC ID), 256MB/512MB RAM, Allwinner XR819 SDIO Wi-Fi, a MicroUSB port which is used to power the board (also capable of OTG), a USB Type-A socket and a MicroSD slot. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-11ARM: sunxi: remove bare default for CONFIG_MMCMasahiro Yamada
The bare default entry is wrong. Just remove it since the (real) entry in drivers/mmc/Kconfig has "default ARM || PPC || SANDBOX". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-04sunxi: A64: enable SPLAndre Przywara
Now that the SPL is ready to be compiled in AArch64 and the DRAM init code is ready, enable SPL support for the A64 SoC and in the Pine64 defconfig. For now we keep the boot0 header in the U-Boot proper, as this allows to still use boot0 as an SPL replacement without hurting the SPL use case. We disable FEL support for now by making its compilation conditional and disabling it for ARM64, as the code isn't ready yet. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
