path: root/board/stxxtc/u-boot.lds
2005-08-15Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board.Wolfgang Denk
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005
