path: root/board/stxssa
2009-01-23fsl-ddr: use the 1T timing as default configurationDave Liu
For light loaded system, we use the 1T timing to gain better memory performance, but for some heavily loaded system, you have to add the 2T timing options to board files. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-27FSL DDR: Convert STXSSA to new DDR code.Kumar Gala
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-1785xx: Convert STXGP3 & STXSSA to new TLB setupKumar Gala
2008-01-1685xx: Use proper defines for PCI addressesKumar Gala
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE. While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only be used for configuring the PCI ATMU. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: convert STXGP3/STXSSA over to use new LAW init codeKumar Gala
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_*_ADDR as the base of the registers instead of getting it via &immap. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t for guts offset on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_GUTS_ADDR as the base of the guts registers instead of getting it via &immap->im_gur. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-12Fix memory corruption problem on STX GP3 SSA Board.Wolfgang Denk
2007-09-11[GP3SSA] Add define CONFIG_MPC85XX_PCI2 in config file to allow u-boot toGrzegorz Bernacki
scan on second pci bus. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-07-06Code cleanup and default config update for STC GP3 SSA board.Wolfgang Denk
2007-05-31Add support for STX GP3SSA (stxssa) Board with 4 MiB flash.Wolfgang Denk
2007-05-03Cleanup STX GP3SSA code; fix build and compile problems.Wolfgang Denk
2007-05-03Add support for STX GP3SSA (stxssa) BoardDan Malek
Signed-off-by Dan Malek, <dan@embeddedalley.com>
