Move files belonging to the STx boards into common vendor directory and
update the Makefile to reflect this.
Signed-off-by: Alex Dubov <oakad@yahoo.com>
For historic reasons we had defined some additional PLATFORM_CPPFLAGS
like:
PLATFORM_CPPFLAGS += -DCONFIG_E500=1
PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1
PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1
However these are all captured in the config.h and thus redudant.
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
For light loaded system, we use the 1T timing to gain better
memory performance, but for some heavily loaded system,
you have to add the 2T timing options to board files.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Because some dimm parameters like n_ranks needs to be used with the board
frequency to choose the board parameters like clk_adjust etc. in the
board_specific_paramesters table of the board ddr file, we need to pass
the dimm parameters to the board file.
* move ddr dimm parameters header file from /cpu to /include directory.
* add ddr dimm parameters to populate board specific options.
* Fix fsl_ddr_board_options() for all the 8xxx boards which call this function.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Affected boards:
cu824
bab7xx
adciop
dasa_sim
mousse
mpc8540eval
musenki
mvblue
pcippc2/pcippc6
sbc8240
stxssa
Removed initialization of the driver from net/eth.c
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
With the new LAW interface (set_next_law) we can move to letting the
system allocate which LAWs are used for what purpose. This makes life
a bit easier going forward with the new DDR code.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
Acked-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
When we go to 36-bit physical addresses we need to keep the concept of
the physical CCSRBAR address seperate from the virtual one.
For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR
Many of the spd.h #includers don't need it,
and wanted to have spd_sdram() declared instead.
Since they didn't get that, some also had open
coded extern declarations of it instead or as well.
Fix it all up by using spd_sdram.h where needed.
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE.
While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only
be used for configuring the PCI ATMU.
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
The old macros made it difficult to know what WIMGE and perm bits
were set for a TLB entry. Actually use the bit masks for these items
since they are only a single bit.
Also moved the macros into mmu.h out of e500.h since they aren't specific
to e500.
In the future the offsets to various blocks may not be in same location.
Move to using CFG_MPC85xx_*_ADDR as the base of the registers
instead of getting it via &immap.
Move to using CFG_MPC85xx_GUTS_ADDR as the base of the guts registers
instead of getting it via &immap->im_gur.
scan on second pci bus.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by Dan Malek, <dan@embeddedalley.com>
