path: root/board/stxgp3
2009-08-28stx: create common vendor/board hierarchy for STx boardsAlex Dubov
Move files belonging to the STx boards into common vendor directory and update the Makefile to reflect this. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 However these are all captured in the config.h and thus redudant. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-23fsl-ddr: use the 1T timing as default configurationDave Liu
For light loaded system, we use the 1T timing to gain better memory performance, but for some heavily loaded system, you have to add the 2T timing options to board files. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-08-27FSL DDR: Convert STXGP3 to new DDR code.Kumar Gala
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-1785xx: Convert STXGP3 & STXSSA to new TLB setupKumar Gala
2008-01-1685xx: Use proper defines for PCI addressesKumar Gala
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE. While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only be used for configuring the PCI ATMU. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: convert STXGP3/STXSSA over to use new LAW init codeKumar Gala
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_*_ADDR as the base of the registers instead of getting it via &immap. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t for guts offset on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_GUTS_ADDR as the base of the guts registers instead of getting it via &immap->im_gur. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-19* Fix a bunch of compiler warnings for gcc 4.0Jon Loeliger
Signed-off-by: Matthew McClintock <msm@freescale.com>
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-07-25* Patch by Jon Loeliger, 2005-07-25Jon Loeliger
Move the TSEC driver out of cpu/mpc85xx as it will be shared by the upcoming mpc83xx family as well.
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-08-01Patch by Jon Loeliger, 16 Jul 2004:wdenk
- support larger DDR memories up to 2G on the PC8540/8560ADS and STXGP3 boards - Made MPC8540/8560ADS be 33Mhz PCI by default. - Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16 and CONFIG_L2_INIT_RAM options. - Refactor Local Bus initialization out of SDRAM setup. - Re-implement new version of LBC11/DDR11 errata workarounds. - Moved board specific PCI init parts out of CPU directory. - Added TLB entry for PCI-1 IO Memory - Updated README.mpc85xxads
2004-04-25Make compile clean.U-Boot-1_1_1wdenk
2004-04-18* Patch by Dan Malek, 07 Apr 2004:wdenk
- Add support for RPC/STx GP3, Motorola 8560 board - Update 85xx TSEC driver so it searches MII for first available PHY and uses that one. - Add functions to support console MII commands. * Patch by Tolunay Orkun, 07 Apr 2004: Move initialization of bi_iic_fast[] from board_init_f() to board_init_r() * Patch by Yasushi Shoji, 07 Apr 2004: Cleanup microblaze port * Patch by Sangmoon Kim, 07 Apr 2004: Add auto SDRAM module detection for Debris board
