path: root/board/stx
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28stx: create common vendor/board hierarchy for STx boardsAlex Dubov
Move files belonging to the STx boards into common vendor directory and update the Makefile to reflect this. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
