These have not been converted to Generic Board, so should be removed.
(See doc/README.generic-board for details.)
Cc: Dan Malek <dan@embeddedalley.com>
The "S: Orphan" in MAINTAINERS means that the maintainer in the
"M:" field is unreachable (i.e. the email address is not working).
(Refer to the definition of "Orphan" adopted in U-Boot
in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b,
"boards.cfg: move boards with invalid emails to Orphan")
For patch files adding global changes, scripts/get_maintainer.pl
adds bunch of such invalid email addresses, which results in
tons of annoying bounce emails.
This commit can be reproduced by the following command:
find . -name MAINTAINERS | xargs sed -i -e '
/^M:[[:blank:]]/ {
N
/S:[[:blank:]]Orphan/s/^/#/
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
Signed-off-by: York Sun <yorksun@freescale.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h
has various parameters with embedded acronyms capitalized that trigger the CamelCase
warning in checkpatch.pl
Convert those variable names to smallcase naming convention and modify all files
which are using these structures with modified structures.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
[trini: Fixup common/cmd_io.c]
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards
pretty much do the same thing. The only variations are in how many
controllers or DIMMs per controller exist. To make this work we
standardize on the names of the SPD_EEPROM_ADDRESS defines based on the
use case of the board.
We allow boards to override get_spd to either do board specific fixups
to the SPD data or deal with any unique behavior of how the SPD eeproms
are wired up.
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq()
and every 86xx board uses get_bus_freq(). If implement get_ddr_freq()
as a static inline to call get_bus_freq() we can remove
fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq()
directly.
Correct initdram to use phys_size_t to represent the size of
dram; instead of changing this all over the place, and correcting
all the other random errors I've noticed, create a
common initdram that is used by all non-corenet 85xx parts. Most
of the initdram() functions were identical, with 2 common differences:
1) DDR tlbs for the fixed_sdram case were set up in initdram() on
some boards, and were part of the tlb_table on others. I have
changed them all over to the initdram() method - we shouldn't
be accessing dram before this point so they don't need to be
done sooner, and this seems cleaner.
2) Parts that require the DDR11 erratum workaround had different
implementations - I have adopted the version from the Freescale
errata document. It also looks like some of the versions were
buggy, and, depending on timing, could have resulted in the
DDR controller being disabled. This seems bad.
The xpedite boards had a common/fsl_8xxx_ddr.c; with this
change only the 517 board uses this so I have moved the ddr code
into that board's directory in xpedite517x.c
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
The include/miiphy.h header duplicates a lot of things from linux/mii.h.
So punt all the things that overlap to keep the API simple and to make
merging between U-Boot and Linux simpler.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names
with spaces drop a
Warning: eth device name has a space!
message. This patch fix it for:
- "FEC ETHERNET" devices found on
mpc512x, mpc5xxx, mpc8xx and mpc8220 boards.
renamed to "FEC".
- "SCC ETHERNET" devices found on
mpc8xx, mpc82xx based boards. Renamed to "SCC".
- "HDLC ETHERNET" devices found on mpc8xx boards
Renamed to "HDLC"
- "FCC ETHERNET" devices found on mpc8260 and mpc85xx based
boards. Renamed to "FCC"
Tested on the kup4k board.
On 85xx platforms we shouldn't be using any LAWAR_* defines
but using the LAW_* ones provided by fsl-law.h. Rename any such
uses and limit the LAWAR_ to the 83xx platform as the only user so
we will get compile errors in the future.
There are really no differences between all the 85xx linker scripts so
we can just move to a single common one. Board code is still able to
override the common one if need be.
Move files belonging to the STx boards into common vendor directory and
update the Makefile to reflect this.
Signed-off-by: Alex Dubov <oakad@yahoo.com>
