path: root/board/stx/stxgp3/Makefile
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2009-08-28stx: create common vendor/board hierarchy for STx boardsAlex Dubov
Move files belonging to the STx boards into common vendor directory and update the Makefile to reflect this. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
