path: root/board/st
2015-07-14Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2015-07-08stm32f4: fix MAINTAINERS fileAntonio Borneo
When "scripts/get_maintainer.pl" parses "board/.../MAINTAINERS", it uses the line containing board name as delimiter. Without this line, the script happily mixes the lines from current board MAINTAINERS file with lines from another file. Fix it by adding a reasonable board name. Tested by comparing output of: cat board/st/stm32f429-discovery/MAINTAINERS ./scripts/get_maintainer.pl -f board/st/stm32f429-discovery Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com> To: u-boot@lists.denx.de To: Kamil Lulko <rev13@wp.pl> Cc: Tom Rini <trini@konsulko.com>
2015-07-03stv0991: configure clock & pad muxing for qspiVikas Manocha
stv0991 has cadence qspi controller for flash interfacing, this patch configures the device pads & clock for the controller. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-05-10stv0991: use fdt for serial port platform dataVikas Manocha
This patch ignores the serial port static platform data at compilation time in case of device tree control. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-10stm32f4: add serial print portkunhuahuang
Add the stm32F4 board's serial ports support. User can use it easily. The user only need to edit the number of the usart. The patch also fix the serial print out. Last, this version of patch fix the first patch checkpatch.pl error. Thanks to Kamil Lulko. Signed-off-by: kunhuahuang <huangkunhua@gmail.com>
2015-04-22stm32f4: Add support for stm32f429-discovery boardrev13@wp.pl
Signed-off-by: Kamil Lulko <rev13@wp.pl> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-12ARM: remove redudant information from Kconfig filesMasahiro Yamada
- "string" type for SYS_* is defined in arch/Kconfig - SYS_CPU "armv7" has been replaced with "select CPU_V7" - SYS_SOC "tegra124" is already defined in tegra124/Kconfig Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2015-01-12stv0991: record defconfig ownership in MAINTAINERSMasahiro Yamada
This commit fixes warnings reported by tools/genboardscfg.py. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Vikas Manocha <vikas.manocha@st.com> Acked-by: Vikas Manocha <vikas.manocha@st.com>
2014-12-09dm: stv0991: Move serial to driver modelVikas Manocha
2014-12-09stv0991: enable ethernet supportVikas Manocha
2014-12-09stv0991: Add basic stv0991 architecture supportVikas Manocha
stv0991 architecture support added. It contains the support for following blocks - Timer - uart Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Add arch/arm/cpu/armv7/Makefile hunk] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-30nomadik: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Nomadik board select menu to nomadik/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="nomadik"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-04-27nhk8815: add support for relocationAlessandro Rubini
This patch defines all the needed symbols in the header file and removes the now-unused config.mk in board directory. Changes to board C file as requested. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2011-04-27nhk8815: remove platform.S, which was unused at link timeAlessandro Rubini
This source file, which I got by the vendor in their own port, was not actually executing because lib-based compilation didn't call lowlevel_init (we have CONFIG_SKIP_LOWLEVEL_INIT). With the change to object-based linking, an undefined symbol in this file started hitting in the final link. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-29arm nomadik: add i2cAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-06arm nomadik: allow Nand and OneNand to coexistsAlessandro Rubini
The evaluation kit has both Nand and OneNand, both drivers are there and the two configurations only select a different default for the jffs partition. This adds the OneNand driver and cleans up storage. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-07-06arm nomadik: rename board to nhk8815Alessandro Rubini
This is an error in my side in the initial submission: nobody calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-02-22Enable Ethernet for Nomadik 8815 Evaluation KitAlessandro Rubini
This trivially enables Ethernet support in the debug board by setting up the proper chip select. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
2009-01-24Initial support for Nomadik 8815 development boardAlessandro Rubini
The NMDK8815 board is distributed by ST Microelectornics. Other (proprietary) code must be run to unlock the CPU before U-Boot runs. doc/README.nmdk8815 outlines the boot sequence. This is the initial port, with basic infrastructure and a working serial port. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
