path: root/board/st/nhk8815/Makefile
2011-04-27nhk8815: remove platform.S, which was unused at link timeAlessandro Rubini
This source file, which I got by the vendor in their own port, was not actually executing because lib-based compilation didn't call lowlevel_init (we have CONFIG_SKIP_LOWLEVEL_INIT). With the change to object-based linking, an undefined symbol in this file started hitting in the final link. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-07-06arm nomadik: rename board to nhk8815Alessandro Rubini
This is an error in my side in the initial submission: nobody calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
